Hello I am trying to set up a gateway for a lot of 433Mhz sensors. I installed directly the Pilight with a simple RF receiver from the web. Both on an esp8266 and an esp32 with the same result.
First of all I seem to have a problem that the gateway doesn’t reply me when I send a command to list protocols. They are listed on the serial port but not on mqtt., but the gateway sends regurlarly status messages on mqtt.
> N: Send on /SYStoMQTT msg {"uptime":65405,"version":"v1.1.1","freemem":21696,"mqttport":"1883","mqttsecure":false,"rssi":-59,"SSID":"Iota","BSSID":"04:42:1A:BE:1A:21","ip":"192.168.1.96","mac":"B4:E6:2D:4A:38:B5","actRec":1,"modules":["Pilight"]}
> N: [ MQTT->OMG ]: {"enabled":true}
> N: PiLight protocols enabled: ["x10","tfa30","tfa2017","tfa","teknihall","techlico_switch","tcm","smartwares_switch","silvercrest","selectremote","secudo_smoke_sensor","sc2262","rsl366","rc101","quigg_screen","quigg_gt9000","quigg_gt7000","quigg_gt1000","pollin","ninjablocks_weather","nexus","mumbi","logilink_switch","kerui_D026","iwds07","impuls","heitech","ev1527","eurodomest_switch","elro_800_switch","elro_800_contact","elro_400_switch","elro_300_switch","ehome","daycom","conrad_rsl_switch","conrad_rsl_contact","cleverwatts","clarus_switch","beamish_switch","auriol","arctech_switch_old","arctech_switch","arctech_screen_old","arctech_screen","arctech_motion","arctech_dusk","arctech_dimmer","arctech_contact","alecto_wx500","alecto_wsd17","alecto_ws1700"]
> N: Send on /PilighttoMQTT msg {"enabled":true}
> N: Send on /SYStoMQTT msg {"uptime":65525,"version":"v1.1.1","freemem":21680,"mqttport":"1883","mqttsecure":false,"rssi":-56,"SSID":"Iota","BSSID":"04:42:1A:BE:1A:21","ip":"192.168.1.96","mac":"B4:E6:2D:4A:38:B5","actRec":1,"modules":["Pilight"]}
The startmessage is
"mqtt_port": "1883",
"mqtt_user": "",
"mqtt_pass": "",
"mqtt_topic": "home/",
"gateway_name": "OpenMQTTGateway_ESP8266_Pilight",
"mqtt_broker_secure": false,
"mqtt_broker_cert": "",
"mqtt_ss_index": 0,
"ota_server_cert": "",
"ota_pass": "OTAPASSWORD"
*wm:[2] Added Parameter: port
*wm:[2] Added Parameter: user
*wm:[2] Added Parameter: pass
*wm:[2] Added Parameter: cert
*wm:[2] Added Parameter: name
*wm:[2] Added Parameter: ota
N: RF_EMITTER_GPIO: 3
N: RF_RECEIVER_GPIO: 0
N: Switching to Pilight Receiver
N: OpenMQTTGateway modules: ["Pilight"]
W: MQTT connection...
N: Connected to broker
The i don’t see any RF receptions not in the serial nor on mqtt… The receiver send nice pulse trains and my other RT433 receiver finds a lot of sensors.
