Hi, I installed Pilight on an esp32 with 433 mhz rf receiver (RX500), I integrated everything into Home Assistant, I’m receiving data from two Digoo DG-R8H temperature/humidity sensors that belong to a small weather station, I receive the signal raw from both sensors but I would like to extract only the ‘temperature’ and ‘humidity’ values by creating two sensors in HA, I have made several attempts but I have not succeeded, do you have any ideas, thank you all, I am attaching some images
