I have installed an ESP32 with esp32dev-rtl_433 and CC1101.
In HomeAssistant i get it connected via MQTT:
And the Data from the Tasmota Interface:
None Devices have beend found.
I want to integrate a Bresser 7 in 1 which is here not supported: RF gateways (433mhz/315mhz) | OpenMQTTGateway v1.6.0
but it is in this GitHub - NorthernMan54/rtl_433_ESP: Trial port of the rtl_433 Library for use with OpenMQTTGateway on a ESP32 and a CC1101 Transceiver
How to i change the decoding to receice to signal?
Thanks a lot
All Pictures in 1 Image:
