I have a very simple 433Mhz remote controlling a retractable patio awning.
3 commands “UP” “DOWN” “STOP”
Generic Chinese remote. No brand, markings or FCC ID.
I have OpenMQTTGateway running on a hacked Sonoff RFBridge (Pilight)
I want to transmit the remote codes via the Sonoff Bridge so I can get rid of the remote and control the awning via Home Assistant.
The remote signals aren’t decoded on existing protocols
SRFB : nothing decoded/no raw signal captured.
Pilight : nothing decoded; can only capture raw signal, however I get a sequence of 5 different raw decodes within a second for a single button press (the remote led blinks half a second)
MQTT Explorer
<i>11/01/2024 12:21:49 AM</i>
{"format":"RAW","rawlen":116,"pulsesString":"c:00110100101010101101010100101010110101001101001011010010101100110101010101010011010011001010101101010100110101012123;p:600,220,1852,4395@"}
<i>11/01/2024 12:21:49 AM*(-0.13 seconds)*</i>
{"format":"RAW","rawlen":114,"pulsesString":"c:012303002020212023030303002020202303030023020020230300202023002202020202020200220200220020202022020202002202020203;p:645,487,268,4826@"}
{"format":"RAW","rawlen":57,"pulsesString":"c:011222223220000040402240402240222222224040445422545454545;p:750,2067,365,1211,648,4786@"}
<i>11/01/2024 12:21:49 AM*(-0.11 seconds)*</i>
{"format":"RAW","rawlen":114,"pulsesString":"c:001101001010101011010101001010101101010011010010110100101011001101010101010100110100110010101011010101001101010102;p:575,203,4816@"}
<i>11/01/2024 12:21:48 AM*(-0.11 seconds)*</i>
{"format":"RAW","rawlen":114,"pulsesString":"c:012202013131312122020202012020202202020022020020220200202022002202020202020200220200220020202022020202002202020203;p:486,636,262,4844@"}
When I try to re-send the captured signals, it generates a much longer (time wise) signal than the original button (same button but different sample than above)
alias: MQTT send
sequence:
- action: mqtt.publish
metadata: {}
data:
qos: 0
retain: false
topic: OMG/OMG_RFBRIDGE/commands/MQTTtoPilight
payload: '{"raw":"c:0000000000010001000000000000120000020000000300000003040040245000000553000003000600000000000600002300006630200000036000606;p:213,1311,699,457,1020,806,4945@"}'
metadata: {}
data:
qos: 0
retain: false
payload: '{"raw":"c:012202013131213122020202002020202202020022020020220200202022002202020202020200220200220020202022020202002202020203;p:491,662,254,4849@"}'
metadata: {}
data:
qos: 0
retain: false
payload: '{"raw":"c:0011010010101010110101010010101011010100201001011010010101100110101010101010011010030101010110101010011010101041560110100227;p:572,198,302,913,2609,1970,746,5817@"}'
metadata: {}
data:
qos: 0
retain: false
payload: '{"raw":"c:0011000210000001001131313131310033430043000000004143434330434343434;p:377,763,1113,648,4793@"}'
metadata: {}
data:
qos: 0
retain: false
payload: '{"raw":"c:001101001010101011010101001010101101010011010010110100101011001101010101010100110100110010101011010101001101010102;p:630,249,4833@"}'
description: ""
I haven’t installed the awning yet to test it but this doesn’t look right at first glance…
I also managed to generate a flex decoder with RTL-433 but not sure if If there’s a way to use their format/parameters to send in OMG.
More details here: https://groups.google.com/g/rtl_433/c/AgcIjjnwz1w
Let me know what you think,
how should I troubleshoot this / best course of action.
