Oekel
December 16, 2023, 4:41pm
1
I am totally new here (And sorry to say I don’t see the benefits of OMG yet → Compared to Tasmota; But I give a try ;). )
I have the following ESP32 Board:
(Need Wifi + LAN (PoE)
As you see I have the following free Pins:
IO 02
IO 04
IO 12
IO 14
IO 15
IO 16
IO 32
IO 33
IO 34
IO 35
IO 36
IO 39
Sucessfully flashed Tasmota and everythink working with this on the pins
Now to give OMG the first try with this board I need to know how each bin is preconfigured and what to do to get LAN working.
Additionaly your docu is talking about GPIO 27 & 12 as defaults for SRX882s + STX882
How to change them? Before build or in some dynamic config during run?
After all what con be configured after first flash?
Greatings Oekel
PS: Might it be possible to flash your *.bin (there are allways 2?) within OTA of Tasmota and wise versa?
Oekel
January 2, 2024, 9:51am
2
Happy new Year!
How active is the community here? Did I ask the question so badly or violate some rules or does it still count as usual not to get an answer for several weeks?
(I really don’t mean any offense, but as a newbie I can only warm up to a project if I’m given help.)
Tasmota changed partition layout. Not compatible
Oekel
January 2, 2024, 2:35pm
4
OK,
what woult be a good template/base to work with?
I have the following PinMap
Supported Boads like:
ESP32-POE IoT development board with 100Mb Ethernet, Power over Ethernet, WiFi, BLE, programmer
Have “blocked” GPIO34/39 and seems not to be a good choice.
I currently try to add an OMG_t-Internet-POE_env.ini but not feeling fine with existing documentation
DigiH
January 2, 2024, 2:50pm
5
A bit more forum searching and reading might also help to clarify things, I hope.
Probably a stupid newbie question again…
I’m working with a portable environment “platform_custom_env.ini”.
I created some custom environments with my custom settings, i.e.
; esp32-rf-custom
[env:esp32-rf-custom]
extends = env:esp32dev-rf
${env:esp32dev-rf.lib_deps}
${env:esp32dev-rf.…
And also in your custom env.ini you want your default_envs to have the name of your custom environment.
[platformio]
default_envs = nodemcuv2-rf-bart
depending on how you build and upload it.
Thank you for this!
I’ll give it a shot and report back.
Thank you!
