Thanks, I’ve added that , but still no RF reception at all.
I noticed that when I send <>MQTTtoRF2 or <>MQTTto433 as active=true that I get a confirmation from RF2toMQTT and 433toMQTT. But I do not get that when I send MQTTtoRTL_433 active=true:
OpenMQTTGateway
LWT = online
version = version_tag
▼commands
MQTTtoIR = {“hex”:“0xFFF00F”,“protocol_name”:“NEC”}
MQTTtoRF2 = {“active”:true}
MQTTtoRTL_433 = {“active”:true}
MQTTto433 = {“active”:true}
BTtoMQTT (5 topics, 34 messages)
IRtoMQTT = {“value”:16722135,“protocol”:3,“bits”:32,“hex”:“0xFF28D7”,“protocol_name”:“NEC”,“raw”:“9030,4600,514,636,508,610,536,612,508,638,636,506,512,610,510,632,514,610,534,1754,514,1754,510,1754,538,1752,514,1754,512,1752,540,1752,516,1752,512,634,512,608,538,1754,512,612,534,1756,510,612,536,610,510,636,510,1756,512,1752,540,634,486,1752,538,636,482,1754,540,1754,514,1752,512”}
SYStoMQTT = {“uptime”:244,“version”:“version_tag”,“freemem”:133040,“freestack”:4188,“rssi”:-55,“SSID”:“ASSY2.4”,“ip”:“172.16.51.149”,“mac”:“94:B9:7E:E5:47:E0”,“lowpowermode”:0,“btqblck”:0,“btqsum”:11,“btqsnd”:11,“btqavg”:1,“interval”:55555,“scanbcnct”:10,“scnct”:4,“actRec”:2,“mhz”:433.92,“modules”:[“IR”,“RF”,“RF2”,“Pilight”,“BT”]}
433toMQTT = {“active”:true}
RF2toMQTT = {“active”:true}
I also noticed during compyling with platformIO that I get quite some warnings, could that be the cause?
Library Manager: Installing build_flags
Warning! Could not find the package with ‘build_flags’ requirements for your system ‘windows_amd64’
Library Manager: Installing -w
Warning! Could not find the package with ‘-w’ requirements for your system ‘windows_amd64’
Library Manager: Installing true’
Warning! Could not find the package with ‘true’’ requirements for your system ‘windows_amd64’
Library Manager: Installing “HADiscovery”’
Warning! Could not find the package with ‘“HADiscovery”’’ requirements for your system ‘windows_amd64’
Library Manager: Installing 1’
Warning! Could not find the package with ‘1’’ requirements for your system ‘windows_amd64’
Library Manager: Installing ‘-DCONFIG_BT_NIMBLE_ROLE_PERIPHERAL_DISABLED’
Warning! Could not find the package with ‘’-DCONFIG_BT_NIMBLE_ROLE_PERIPHERAL_DISABLED’’ requirements for your system ‘windows_amd64’
Library Manager: Installing ‘-DCONFIG_BT_NIMBLE_ROLE_BROADCASTER_DISABLED’
Warning! Could not find the package with ‘’-DCONFIG_BT_NIMBLE_ROLE_BROADCASTER_DISABLED’’ requirements for your system
‘windows_amd64’
Library Manager: Installing ‘-DMQTTsetMQTT’
Warning! Could not find the package with ‘’-DMQTTsetMQTT’’ requirements for your system ‘windows_amd64’
Library Manager: Installing ‘-DMQTT_HTTPS_FW_UPDATE’
Warning! Could not find the package with ‘’-DMQTT_HTTPS_FW_UPDATE’’ requirements for your system ‘windows_amd64’
Library Manager: Installing “RF”’
Warning! Could not find the package with ‘“RF”’’ requirements for your system ‘windows_amd64’
Library Manager: Installing “RF2”’
Warning! Could not find the package with ‘“RF2”’’ requirements for your system ‘windows_amd64’
Library Manager: Installing “IR”’
Warning! Could not find the package with ‘“IR”’’ requirements for your system ‘windows_amd64’
Library Manager: Installing “BT”’
Warning! Could not find the package with ‘“BT”’’ requirements for your system ‘windows_amd64’
Library Manager: Installing “Pilight”’
Warning! Could not find the package with ‘“Pilight”’’ requirements for your system ‘windows_amd64’
Library Manager: Installing “rtl_433”’
Warning! Could not find the package with ‘“rtl_433”’’ requirements for your system ‘windows_amd64’
Library Manager: Installing “CC1101”’
Warning! Could not find the package with ‘“CC1101”’’ requirements for your system ‘windows_amd64’
Library Manager: Installing “OpenMQTTGateway_ESP32_HUB”’
Warning! Could not find the package with ‘“OpenMQTTGateway_ESP32_HUB”’’ requirements for your system ‘windows_amd64’
Library Manager: Installing 4’
Warning! Could not find the package with ‘4’’ requirements for your system ‘windows_amd64’
Found 40 compatible libraries
