Hallo all,
I am using OpenMQTTGateaway on a ESP8266 MCU Board.
Everything is install well. Thanks to the Programmer ! Very nice Programm.
I have a RF 433 Mhz Wall-Switch. The codes for this wall switch is
4523285 for ON
4523284 for OFF
So far so good. If I send the ON Code Manualy over Publish MQTT to the Topic home/OpenMQTTGateway/commands/MQTTto433
{ “value”:4523285,“protocol”:1,“length”:24,“delay”:313}
The Wallswitch turn ON. Nice
If I send the OFF Code Manualy over Publish MQTT to the Topic home/OpenMQTTGateway/commands/MQTTto433
The Wallswitch turn OFF. Also Verry Nice
{ “value”:4523284,“protocol”:1,“length”:24,“delay”:313}
In my HA configuration.yaml I put this lines.
switch:
- platform: mqtt
state_topic: home/OpenMQTTGateway/commands/MQTTto433
command_topic: home/OpenMQTTGateway/commands/MQTTto433
value_template: ‘{{ value_json.state }}‘
payload_on: ‘{ “value”:4523285,“protocol”:1,“length”:24,“delay”:313 }‘
payload_off: ‘{ “value”:4523284,“protocol”:1,“length”:24,“delay”:313 }‘
state_on: “on”
state_off: “off”
optimistic: “true”
qos: 1
retain: true
Then I checked the Config in HA and I got no Errors. Then Reboot HA.
Create a Card in HA. like this.
But it is not working…
So I read the Docs so many time. But I can’t find a solution.
Reading here in the Forum, trying so many Configuration in the Configuration.Yaml
nothing helpt me.
Now I am living under the Rock.
Maybe someone can help me. Sorry for the Pain but im only a Electronik Engineer but not
a good Programmer. If someone have question about Electronik, No Problem for me. Working more than 42 Years now, for the biggest Elektronik Company. But now I’m giving up, with that stupid Configuration.Yaml. So please give me a clue…
Best regards
Juergen
