Hi! I registered to ask a question about this. I finally got around to try to flash my LoRa 32. It’s a V3, because it has a USB type C. I bought it from Aliexpress this fall to replace the Tellstick when that went paywall but it won’t work. Every time I try, no matter what button I press, I get
Failed to initialize. Try resetting your device or holding the BOOT button while selecting your serial port.
Is this because this chip is still not supported, or am I doing something wrong?
And I don’t really understand the OOK references, even after googling for a while. Is Oregon and similar temperature sensors OOK, or are they another protocol?
I’m not at all a newbie with ESP32, I have at least 20 of them in my house, my car, my boat and my cabin with hundreds of lines of code in ESPHome, but OpenMQTTGateway is new for me. And so is working with libraries and creating the flash program from the ground up.
Thanks! And damn… So I have basically wasted my money because I was told by a guy on another forum that this would work, and I didn’t check anymore. You obviously know these things, so maybe you could tell me if that limitation is in OpenMQTT Gateway or in the hardware. I saw that another guy in the previous thread had gottins his to work with another system, but will it still not be able to read the sensors?
