Hi, I’m having a hard time make it to work - no BLE device is being detected on the serial or MQTT interfaces.
I use some ESP8266 nodeMCU board with HM-10 module. I’ve just upgraded it to 710v firmware and did all is written in HM10 + ESP8266 Unable to get OMG Working
The output from the serial monitor is:
23:39:53.253 -> rld⸮⸮|⸮l⸮|⸮l⸮c|⸮⸮⸮⸮;⸮c⸮c⸮⸮gn⸮dog⸮⸮⸮c8⸮⸮lrd;lx⸮o⸮⸮$⸮⸮#'⸮|⸮l⸮⸮b⸮⸮og⸮l⸮⸮l`⸮eg'l`aorǛ⸮ncd`{⸮⸮ocl ⸮c⸮⸮$r⸮`⸮⸮'⸮N: ⸮{"mqtt_server":"10.0.0.59","mqtt_port":"1883","mqtt_user":"","mqtt_pass":"","mqtt_topic":"home/","gateway_name":"OpenMQTTGateway"}*WM: [3] allocating params bytes: 20
23:39:53.362 -> *WM: [2] Added Parameter: server
23:39:53.362 -> *WM: [2] Added Parameter: port
23:39:53.400 -> *WM: [2] Added Parameter: user
23:39:53.400 -> *WM: [2] Added Parameter: pass
23:39:53.400 -> *WM: [2] Added Parameter: name
23:39:53.400 -> *WM: [3] Updated _max_params: 10
23:39:53.400 -> *WM: [3] re-allocating params bytes: 40
23:39:53.400 -> *WM: [2] Added Parameter: topic
23:39:55.367 -> {"mqtt_server":"10.0.0.59","mqtt_port":"1883","mqtt_user":"","mqtt_pass":"","mqtt_topic":"home/","gateway_name":"OpenMQTTGateway"}N: BLE interval: 55555
23:39:56.857 -> N: BLE scans number before connect: 10
23:39:56.857 -> N: Publishing only BLE sensors: false
23:39:56.893 -> N: minrssi: 100
23:39:57.283 -> N: Setup OpenMQTTGateway end
23:39:57.283 -> W: MQTT connection...
23:39:57.387 -> N: Connected to broker
23:39:57.387 -> N: Subject: /SYStoMQTT
23:39:57.387 -> N: Received json : {"uptime":4,"version":"v0.9.5","freemem":38104,"rssi":-43,"SSID":"ABW-51n","ip":"10.0.0.174","mac":"FC:F5:C4:AB:6E:0A","wifiprt":0,"interval":55555,"scanbcnct":10,"modules":"BT"}
The output from the HM-10 on the given commands is:
OK
HMSoft V710
OK+Get:0
OK+Set:1
OK+Set:1
OK+CONN
OK+LOST
OK+DISAS
OK+DISA:bJ'⸮ ⸮⸮e⸮ե⸮⸮⸮*⸮⸮ ⸮% ⸮
OK+DISA:L⸮a⸮/p⸮
⸮L
⸮;Sg
OK+DISA:c⸮烤⸮
⸮LF⸮\
OK+DISA:y⸮⸮ A⸮⸮ J⸮{⸮8⸮i⸮wv⸮⸮~⸮⸮⸮X⸮=⸮
OK+DISA:⸮9⸮8⸮⸮⸮⸮⸮P0[⸮⸮9⸮8⸮⸮
OK+DISA:⸮9⸮8⸮⸮⸮ ATC_F439F8
OK+DISA:rwSV⸮C⸮⸮L⸮⸮j⸮⸮⸮<⸮⸮⸮⸮⸮⸮
OK+DISA:lC⸮⸮⸮P⸮
⸮L
⸮⸮@8
OK+DISA:~⸮⸮8⸮⸮⸮⸮⸮P0[⸮~⸮⸮8⸮⸮
OK+DISA:~⸮⸮8⸮⸮⸮ ATC_9A927E
OK+DISA:⸮⸮⸮
⸮L⸮⸮⸮
OK+DISA:⸮e⸮T{⸮
a⸮La2⸮⸮x⸮h
OK+DISA:⸮⸮Nvk⸮⸮L⸮⸮j⸮⸮⸮<⸮⸮⸮⸮⸮⸮
OK+DISA:⸮H⸮⸮W⸮
⸮LA\⸮
OK+DISA:0(84-X⸮⸮⸮P ⸮⸮0(84-X
OK+DISA:0(84-X⸮ MJ_HT_V1
OK+DISA:0|⸮⸮⸮e⸮uB⸮`⸮⸮|0⸮⸮|/
OK+DISCE
What could I do next?
