Hi
I try to understand how to define Actuators for mega 2560.
I need to define 32 pins to Actuators.
I have very very low skills with code.
I thought i only need to add more lines
#ifndef ACTUATOR_ONOFF_GPIO
ifdef ESP8266
define ACTUATOR_ONOFF_GPIO 15 //12 for sonoff basic relay
elif ESP32
else
define ACTUATOR_ONOFF_GPIO 24
define ACTUATOR_ONOFF_GPIO 25
define ACTUATOR_ONOFF_GPIO 26
define ACTUATOR_ONOFF_GPIO 27
define ACTUATOR_ONOFF_GPIO 28
define ACTUATOR_ONOFF_GPIO 29
just add it like this. or where should i do it?
If actuatorONOFF is defined you need to leverage one of those commands:
One gateway, many technologies: MQTT gateway for ESP8266, ESP32, Sonoff RF Bridge or Arduino with bidirectional 433mhz/315mhz/868mhz, Infrared communications, BLE, beacons detection, mi flora / mi jia / LYWSD02/ Mi Scale compatibility, SMS & LORA.
Preferably the json ones.
HI
I have try to send this command but nothing happen.
should I delete all of this line?
will i still be discover by home assistant?
Could you share the files that you have modified ?
okay here are a link to my own cloud server. there you have the complett project code
Hi don’t know if you have seen the link i post
I have seen it yes. I need sometime to dig into it
