Hi OMG community. Hopefully you can help me along a bit. I am using the Lilygo T.3v1.6.1 Lora 3 board with lilygi-rtl_433 firmware which workes perfectly. It is now getting my 433 device transmissions and piping them thru to my HA MQTT server like a treat. I do have one question tho. I want to hard set the IP address of the gateway. I can see that it has picked up the DHCP assigned address nnn.nnn.nnn.58 displayed on the OLED. When I try to log on to that address it requires a username and password. I have not seen a username set anywhere (except for the MQTT user/pass info), so I am not sure what that might be. Do you have any idea of the username and password to use connecting via the LAN to set a fixed IP address? Thanks again jules
Show less
