Hey everyone,
I am new to OpenMQTTGateway & want advice on integrating it with my home automation system. I have been experimenting with an ESP32 board and a couple of sensors I have successfully flashed the firmware.
My goal is to have OpenMQTTGateway push the sensor data to my MQTT broker I am using with Home Assistant. While I have been able to get some data flowing, I am facing issues with consistency—sometimes the sensors seem to stop sending data altogether.
I am also exploring AWS tools as part of my learning journey, including the AWS DevOps certification path & wondering if anyone has experience using cloud services alongside OpenMQTTGateway?
I want to eventually add some Bluetooth devices to the setup but I am not sure what is the best way to configure everything. Are there any settings or tweaks that I should be aware of to improve reliability?
Also i have check this Integrating OpenMQTTGateway with Home Assistant for Multi-Sensor Automation still need your help.
If anyone has a similar setup or any tips for troubleshooting, I want to hear your thoughts.
Thank you… ![]()
