Issues with the WT32-ETH01 and CC1101
I have been trying for a while to install OMG on a WT32-ETH01 with the CC1101 antenna following the instructions from the following post:
I added the environment: esp32dev-multi_receiver-eth01
2024-09-06 10_18_21-Window
Then I modified the pins in the Config_RF files and in the ELECHOUSE file.
2024-09-12 16_23_42-Window
The upload seems to be going well
However, I am getting the following error with a board that continuously reboots with the following message:
ELF file SHA256: c8d224ce537780b8
E (589) esp_core_dump_flash: Core dump flash config is corrupted! CRC=0x7bd5c66f instead of 0x0
Rebooting...
ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13924
ho 0 tail 12 room 4
load:0x40080400,len:3600
entry 0x400805f0
Guru Meditation Error: Core  0 panic'ed (LoadStoreError). Exception was unhandled.
Core  0 register dump:
PC      : 0x40126968  PS      : 0x00060930  A0      : 0x8012d30c  A1      : 0x3ffe3b30
A2      : 0x3f4188b0  A3      : 0x3f420b24  A4      : 0x00000004  A5      : 0x00060f23
A6      : 0x00060f20  A7      : 0x00000001  A8      : 0x80126968  A9      : 0x3ffe3b10
A10     : 0x3ffbb228  A11     : 0xfffc1fff  A12     : 0x00060f20  A13     : 0x00060f23
A14     : 0x007becb8  A15     : 0x003fffff  SAR     : 0x00000018  EXCCAUSE: 0x00000003
EXCVADDR: 0x3f4188b0  LBEG    : 0x4008aadd  LEND    : 0x4008aaed  LCOUNT  : 0xfffffffe
Backtrace: 0x40126965:0x3ffe3b30 0x4012d309:0x3ffe3b50 0x40126918:0x3ffe3b70 0x40124fae:0x3ffe3b90 0x40125379:0x3ffe3bb0 0x400e4601:0x3ffe3bd0 0x4014478f:0x3ffe3c10 0x4008321a:0x3ffe3c40 0x40079276:0x3ffe3c90 |<-CORRUPTED
I tried setting up a personal environment, but being new to PlatformIO, I am encountering errors that I cannot resolve.
Could you confirm whether the data provided in the original post is still valid for version 1.7.0?
Thank you for your help
Exact the same for me. But trying since 1 week and don’t get the problem.
[   129][E][Preferences.cpp:47] begin(): nvs_open failed: NOT_FOUND
N: SYS config not found
N: OpenMQTTGateway Version: edge
N: OTA server cert hash: 02118cbaf5cc02748398d93ecdb0ef2a444c37358a617bfb2206dfe351dc7cf2
N: Config loaded from flash
N: Spl eth cfg
N: Ethernet started
N: .
N: .
N: .
N: .
N: .
N: .
[ 10853][E][Preferences.cpp:47] begin(): nvs_open failed: NOT_FOUND
N:
N: Spl eth cfg
N: Ethernet started
N: .
N: .
N: .
N: .
N: .
N: .
[ 10925][E][Preferences.cpp:47] begin(): nvs_open failed: NOT_FOUND
N:
And repeating that…
