KeeYees ESP32 WROOM + EBYTE E07 CC1101 module
Morning folks,
I have uploaded the esp32dev-rtl_433 firmware and connected it to my wifi successfully. The rest Im not 100% its connecting to mqtt successfully or that it is receiving any data, Im hoping to pick up the transmission from the sensor in my oil tank, I can get the data from my SDR but the cost of the device doesnt seem like a good idea.
My question is, did I choose the right firmware to upload via the web? Are there any commands I can send it via an mqtt topic to check what it is doing?
edit:
This is from the serial monitor
*WM: [1] ESP-IDF version: v3.3.4-432-g7a85334d8
I got it working! The problem was my breadboard I was using to hold it, it was shorting somewhere!!!
