i tried to login with
Open MQTTGateway_lilygo_rtl_433_ESP
opengate mqtt gives after flashing on the screen:
W1FOMG_lilygo_rtl_433_ESP
but
not any answer or possibility to login
The good is:
network gives: OMG_lilygo_rtl_433_ESP
but no credential key is present.
that is why i want to renew the whole procedure??
so i cannot give my secrets to create something
Who can gives me advice
gr
Dick
thanks
the download with lilgy-rtl_433 is ok.
i use the adress from the oled screen.
But after that download it is not possible to get a connection with my smartphone.
Project stops
DigiH,
Thanks to you and others is it possible to get
lilygo_rtl_433
in esp/lolin.
but then
i give that adress from the oled screen to my smartphone
W1FOMG_lilygo_rtl_433_ESP your_password
that stops
I dont see that image that is mentioned on wifi and configuration
OpenMQTTGateway
WIFiManager
so i cannot configure to complete the whole installation.
question 1 is that adres (W1…) correct. If not what is that right adres?
2. is there a manner to get entrance to Wifi Manager portal?
trying to Erase the ESP settings wtih
mosquitto_pub -t “home/OpenMQTTGateway/commands/MQTTtoSYS/config” -m ‘{“cmd”:“erase”}’
apears in the record with networkadresses
Trying to connect is out of order or there is no connection.
But
SSID is that case OMG_lilygo_rtl_433_ESP
ip4 gives 192.162.4.1
