Lilygo 433 rtl Error: Didn't get enough status bytes
@DigiH Well, that seems to have done it on MacOS. It was an incorrect USB driver. Once I installed the one you provided and tried again, the flash finished up correctly. Thanks for the continued ideas and finding the right solution. With both drivers installed, I made sure to select the WCH one and the install finished without issue.
