Lilygo 915mhz support - New User
Hello!
New user here, I have an existing 433mhz Lilygo device which I was able to get set up with OpenMQTT, and I loved it so much, I decided to buy the 900mhz version of the device for monitoring my municipal water usage which transmits via SCM Plus which I currently do with an SDR USB adapter plugged into a Raspberry Pi.
Firstly, it appears I need to change the frequency on the device as the recompiled version has 433.92mhz:
I did this via the console:
commands/MQTTtoRTL_433 {“mhz”:915}
Unfortunately, I don’t get any results at all, unlike my USB adapter.
Secondly, when I do a reboot on the device, it resets the device back to 433mhz.
So my two questions. 1) How to I make my device stick to the 900mhz frequency and 2) Am I doing this incorrect, or something else?
Thank you for your patience!
I am looking to do the same with my gas/electricity meters
(915mhz lilygo scm/scm+ readings but no luck yet)
There also might be some good info in this thread: LILYGO TTGO LoRa32 V2.1_1.6 915 MHz - #25 by pyrodex
