I have tried 2 different LilyGO board models and both stopp responding after a few hours. One board is the LilyGO T-BEAM (Model:LORA32)) and a LilyGO Model T3 V1.6.1. I loaded the firmware from the web installer using the Lilygo rtl-433 Installer Item. The boards work for a few hours then stop responding and must be rebooted.
Any suggestions?
I just posted the same 30 mins ago
Could you try to catch the serial log output when it hangs?
Also are you with v1.5.1 or development version.
Currently I am unable to access the web interface for the device. It is intermittenly available for some reason. I instaled the firmware form Option 1 on the web install using the LILIGo RTL-433. For the T-BEAM device I loaded the TTGO-T-BEAM option but this version does not run on the device, however, the LILIGO RTL-433 version does work but stops responding after a few hours. Both devices exhibit intermittent access to the devices web interface.
With which version of OMG are you ?
I am running 1.51 I believe. The version included on Option 1 of the web installer.
If you had access to a web interface after the onboarding (by the IP of the gateway) you should be on the development version
To confirm you can connection to your MQTT broker and look for it:
I am on the 1.5.1 version. Appearently the web installer Option 1 installs the dev version. Note that I have been testing this for about 2 months and experienced the same problem all along.
There are two web installers:
Production for regular usage:
(Option 1) Upload from the web | OpenMQTTGateway v1.5.1 -
Development for testing:
(Option 1) Upload from the web | OpenMQTTGateway DEVELOPMENT SHA:479ac5 TEST ONLY
You should use the first one for your regular usage. The second one is for testing and the gateway may not work as expected
I just retested the first one with heltec_rtl433 and got the v1.5.1.
To go further if you are on v1.5.1 we will need the serial logs when the board stops responding. You can get this by connecting the board with an USB cable + platformio.
VSCode and platformio is hard for the unwashed like me
I did manage to get it but esphome flasher is drop dead simple to view the logs
The boards ran for over 2 days before stopping. Here are the last lines from the console log:
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:6,“wind_avg_km_h”:3.21869,“wind_dir_deg”:269,“rain_mm”:125.984,“exception”:0,“raw_msg”:“c169c68188b7f0a0”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:128996}
rtl_433_ESP(7): Average RSSI Signal -109 dbm, adjusted RSSI Threshold -100, samples 50000
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:7,“wind_avg_km_h”:1.60934,“uv”:1,“lux”:8370,“exception”:0,“raw_msg”:“c16947004106c57d”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-75,“duration”:127996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:5,“wind_avg_km_h”:1.60934,“temperature_C”:28.66667,“humidity”:27,“exception”:0,“raw_msg”:“c169c500c9d41ba7”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-75,“duration”:129996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:6,“wind_avg_km_h”:1.60934,“wind_dir_deg”:257,“rain_mm”:125.984,“exception”:0,“raw_msg”:“c169c6004887f0af”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:232996}
N: Send on /SYStoMQTT msg {“uptime”:10922,“version”:“v1.5.1”,“discovery”:false,“env”:“lilygo-rtl_433”,“freemem”:99496,“mqttport”:“1883”,“mqttsecure”:false,“tempc”:50.55556,“freestack”:1724,“rssi”:-43,“SSID”:“AndrewChristinaBrooke”,“BSSID”:“18:31:BF:94:D3:90”,“ip”:“192.168.1.238”,“mac”:“D4:D4:DA:82:EA:BC”,“actRec”:3,“mhz”:433.92,“RTLRssiThresh”:-100,“RTLRssi”:-111,“RTLAVGRssi”:-109,“RTLCnt”:2829,“RTLOOKThresh”:15,“modules”:[“LilyGo_SSD1306”,“rtl_433”]}
N: Send on /SSD1306toMQTT msg {“onstate”:true,“brightness”:50,“displaymetric”:true,“display-flip”:true,“idlelogo”:true,“log-oled”:false,“json-oled”:true}
N: Update checkN: Send on /RLStoMQTT msg {“latest_version”:“v1.5.1”,“title”:“OpenMQTTGateway”,“release_url”:“https://github.com/1technophile/OpenMQTTGateway/releases/tag/v1.5.1",“installed_version”:“v1.5.1”,“entity_picture”:“https://github.com/1technophile/OpenMQTTGateway/raw/development/docs/img/Openmqttgateway_logo_mini_margins.png”,“release_summary”:"”}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:7,“wind_avg_km_h”:4.82803,“uv”:2,“lux”:8570,“exception”:0,“raw_msg”:“c169478142065993”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:127996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:5,“wind_avg_km_h”:8.046721,“temperature_C”:28.61111,“humidity”:27,“exception”:0,“raw_msg”:“c169c582c9531ba8”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:127996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:6,“wind_avg_km_h”:4.82803,“wind_dir_deg”:304,“rain_mm”:125.984,“exception”:0,“raw_msg”:“c169c681c9c3f0ed”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:129000}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:7,“wind_avg_km_h”:4.82803,“uv”:1,“lux”:8670,“exception”:0,“raw_msg”:“c16947814106639c”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:127996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:5,“wind_avg_km_h”:3.21869,“temperature_C”:28.55556,“humidity”:27,“exception”:0,“raw_msg”:“c169c58109d21b66”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-99,“duration”:135997}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:6,“wind_avg_km_h”:4.82803,“wind_dir_deg”:228,“rain_mm”:125.984,“exception”:0,“raw_msg”:“c169c6814793f03b”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:129996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:7,“wind_avg_km_h”:4.82803,“uv”:1,“lux”:8820,“exception”:0,“raw_msg”:“c1694781410672ab”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-75,“duration”:127996}
N: Send on /RTL_433toMQTT/Interlogix-Security/motion/40c582 msg {“model”:“Interlogix-Security”,“subtype”:“motion”,“id”:“40c582”,“battery_ok”:0,“switch1”:“CLOSED”,“switch2”:“CLOSED”,“switch3”:“CLOSED”,“switch4”:“OPEN”,“switch5”:“OPEN”,“raw_message”:“703638”,“protocol”:“Interlogix GE UTC Security Devices”,“rssi”:-88,“duration”:89037}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:5,“wind_avg_km_h”:3.21869,“temperature_C”:28.44444,“humidity”:27,“exception”:0,“raw_msg”:“c169c58109501be4”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:127996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:6,“wind_avg_km_h”:3.21869,“wind_dir_deg”:288,“rain_mm”:125.984,“exception”:0,“raw_msg”:“c169c6810903f06d”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:130000}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:7,“wind_avg_km_h”:1.60934,“uv”:1,“lux”:8920,“exception”:0,“raw_msg”:“c16947004106fcb4”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:127996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:1,“battery_ok”:1,“message_type”:5,“wind_avg_km_h”:0,“temperature_C”:28.38889,“humidity”:27,“exception”:0,“raw_msg”:“c569c50009cf1be6”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:127997}
N: Send on /SYStoMQTT msg {“uptime”:11042,“version”:“v1.5.1”,“discovery”:false,“env”:“lilygo-rtl_433”,“freemem”:99212,“mqttport”:“1883”,“mqttsecure”:false,“tempc”:50.55556,“freestack”:1724,“rssi”:-42,“SSID”:“AndrewChristinaBrooke”,“BSSID”:“18:31:BF:94:D3:90”,“ip”:“192.168.1.238”,“mac”:“D4:D4:DA:82:EA:BC”,“actRec”:3,“mhz”:433.92,“RTLRssiThresh”:-100,“RTLRssi”:-109,“RTLAVGRssi”:-109,“RTLCnt”:2875,“RTLOOKThresh”:15,“modules”:[“LilyGo_SSD1306”,“rtl_433”]}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:6,“wind_avg_km_h”:1.60934,“wind_dir_deg”:83,“rain_mm”:125.984,“exception”:0,“raw_msg”:“c169c60042cff0f1”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:129996}
rtl_433_ESP(7): Average RSSI Signal -108 dbm, adjusted RSSI Threshold -99, samples 50000
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:7,“wind_avg_km_h”:1.60934,“uv”:1,“lux”:9100,“exception”:0,“raw_msg”:“c169470041878ec7”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:127996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:6,“wind_avg_km_h”:3.21869,“wind_dir_deg”:35,“rain_mm”:125.984,“exception”:0,“raw_msg”:“c169c681810ff0f1”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-78,“duration”:129996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:1,“battery_ok”:1,“message_type”:5,“wind_avg_km_h”:1.60934,“temperature_C”:28.38889,“humidity”:28,“exception”:0,“raw_msg”:“c569c500c9cf9c27”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:129996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:7,“wind_avg_km_h”:3.21869,“uv”:1,“lux”:9210,“exception”:0,“raw_msg”:“c169478181879993”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:127996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:5,“wind_avg_km_h”:3.21869,“temperature_C”:28.33333,“humidity”:28,“exception”:0,“raw_msg”:“c169c581094e9c63”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:128996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:6,“wind_avg_km_h”:1.60934,“wind_dir_deg”:109,“rain_mm”:125.984,“exception”:0,“raw_msg”:“c169c600c3b7f05a”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:128996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:7,“wind_avg_km_h”:0,“uv”:1,“lux”:9290,“exception”:0,“raw_msg”:“c16947008187219a”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-87,“duration”:130996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:5,“wind_avg_km_h”:1.60934,“temperature_C”:28.27778,“humidity”:27,“exception”:0,“raw_msg”:“c169c500c94d1b20”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-74,“duration”:159996}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:7,“wind_avg_km_h”:1.60934,“uv”:1,“lux”:9310,“exception”:0,“raw_msg”:“c16947004187a3dc”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-99,“duration”:150995}
N: Send on /SYStoMQTT msg {“uptime”:11162,“version”:“v1.5.1”,“discovery”:false,“env”:“lilygo-rtl_433”,“freemem”:98892,“mqttport”:“1883”,“mqttsecure”:false,“tempc”:50.55556,“freestack”:1724,“rssi”:-43,“SSID”:“AndrewChristinaBrooke”,“BSSID”:“18:31:BF:94:D3:90”,“ip”:“192.168.1.238”,“mac”:“D4:D4:DA:82:EA:BC”,“actRec”:3,“mhz”:433.92,“RTLRssiThresh”:-100,“RTLRssi”:-107,“RTLAVGRssi”:-109,“RTLCnt”:2905,“RTLOOKThresh”:15,“modules”:[“LilyGo_SSD1306”,“rtl_433”]}
N: Send on /RTL_433toMQTT/Acurite-Atlas/A/361 msg {“model”:“Acurite-Atlas”,“id”:361,“channel”:“A”,“sequence_num”:0,“battery_ok”:1,“message_type”:5,“wind_avg_km_h”:0,“temperature_C”:28.22223,“humidity”:28,“exception”:0,“raw_msg”:“c169c50009cc9c60”,“protocol”:“Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas”,“rssi”:-73,“duration”:128995}
Ln 32, Col 2
TTGO LoRa32-OLED
on COM3
This is the end of the log and the board is stuck ?
Yes, that is from the end of the log.
This is all I could see
W: Network disconnected:
*wm:[2] [EVENT] WIFI_REASON: 201
*wm:[2] [EVENT] WIFI_REASON: NO_AP_FOUND
W: wifi
W: wifi
I’m having same problem with my lilygo devices. Used option 1 to install 1.5.1. Any further insights on this?
hello
i have same problem
the gateway not respond
ping fail
Firmware: v1.6.0
This PR adds a task watchdog timer, could you try it ?
Sorry, I didn’t notice this message.
How do I try it?
I’d like to add that I am experiencing the same issue as well, where it will stop functioning after a couple of hours.
