I am pulling my hair out. I am migrating from Domoticz to HAS and i need my Bofu Rollerblinds to work.
I have seen an video from the Swiss tech guy and i assumed the Lilygo Lora 32 could transceive codes to the rollerblind… But reading along the way it cant???
But can i add a C1101 to the port??on some pin to send codes??
First of all i’m completely new in 443mhz/LoRa Hardware so i’m probably made many misconceptions.
I also have a very similar case as Jsutdigit. I needed a solution for control a relay for the underground garage door of my rented apartment. I bought the Lilygo 443 and a 443mhz LoRa relay vom makerfabs. (Lora Relay 30A Module| Makerfabs)
When i received the Lilygo i started to install OMG on it and realized that there is a list that said that the Lilygo can only receive. Is that true? Is there a way to expand the board to achieve what i intend to do?
This is different, with LoRa demodulation we support receiving and sending.
In your case it would be mainly about identifying what the Makerfabs relay is expecting as a command and push it to the gateway:
