I have a couple water meters (SCMplus) that I was able to work with RTL_433 on a Raspberry Pi, but haven’t had luck so far with this solution. I’m wondering if there is any additional configuration I’d need ensure FSK on 915mhz enabled?
I changed the frequency to 912.6 (912.600155 gets truncated in the UI) but I’m not getting anything. I wonder if this would be an indication that the Lilygo isn’t compatible with that frequency. (Board lists 868/915mhz)
Unfortunately not. I use another SDR connected to a Pi for my water meter. I shelved mine some time ago.
I do have another Lilygo for 433mhz that works well to pick up weather stations, but the 900mhz unit I could not get up and running for my water meter.
