LILYGO® TTGO LoRa32 V2.1_1.6 SX1276 868MHz CH9102
I have the LILYGO® TTGO LoRa32 V2.1_1.6 board and i would like to read the sensors of a Besser 7 in 1 (868MHz).
I have uploaded the lillygo_rtl_433 firmware from the web upload
then i tried to change the frequency using the command below in the web console but nothing happend. Is it possible to get this working with my hardware? if so, what do i need to do?
commands/MQTTtoRTL_433 {“mhz”:315.026}
The weather station:
The lora board
This device uses FSK encoding
The pre-built firmware of the v1.6.0 supports OOK decoding only, from this you have several possibilities:
Hi.
Thanks for your reply. I can see that the pull request has been merged now. How do I install the nightly build?
You can install them from below:
Thanks for your help and the project.
I uploaded the liligo-rtl_433-fsk from the link above.
then I changed the frequency to 868.3 and after a restart, my weather station was recognized and data started coming through on MQTT!
it also picked up a BRESSER Thermo-/Hygro-Sensor 7 Channel 868 MHz inside sensor as a 6 in 1 Bresser weather station.
Thanks again!
how did you do that if I may ask?
I am using version b31706 of the firmware.
I can change the frequency by accessing the web interface and selecting
configuration → configure RF and typing in the correct frequency and hit save.
thank you I’ll try that
