Hello folks,
I would like to set up my ESP32 with ZgatewayRFM69. However, my I have limited knowledge of coding in order to see how I might go about this. Please help by answering a few questions for me. I’ll be happy to contribute back to the community by creating a complete tutorial for others to use.
What is the pinout from the rfm69 to the ESP?
How do I assign the frequency? What about the high power radios?
How do I assign the encryption key?
Should I be using the board and library versions referenced in platformio.ini?
Thank you for a great project.
For my curiosity, could you say more about your use case?
I haven’t seen a lot of traction around RFM69, so I would like to understand the purpose of using it.
Also you may find some informations about RFM69 into the wiki
I wish to have the ability to use wireless as well as the TLS and CA certificate credentials for MQTT broker connections. They are not availible with the current RFM69 gateway I have in use today. I have working versions of RFM nodes (choose_nodes_MiF9r1_pub) and a gateway (RFM_MQTT_Gaeway_25.4_pub) from the https://homeautomation.proboards.com/ that utilize Uno and pro-mini boards. You can download the ino files here Google Drive Folder or register for access to the homeautomation board.
You can try to create a platformio.ini environment for RFM69 on ESP32 but I cannot guarantee it will work
[env:esp32dev-rfm69]
board = esp32dev
${libraries.rfm69}
${libraries.rfm69spi}
'-DZgatewayRFM69="RFM69"'
You can modify the pinout, frequency, and encryption key into config_RFM69.h
I’ve successfully compiled the code and loaded onto an ESP32 dev. Can you please double-check my pinout below.
Here’s the code from config_RFM69.h
#elif defined(ESP32)
# define RFM69_CS 1 // NSS
# define RFM69_IRQ 15 // GPIO15/D8 DIO0
# define RFM69_IRQN digitalPinToInterrupt(RFM69_IRQ)
# define RFM69_RST 4 // GPIO02/D4
And pinout
| RFM69 Module |
ESP32 |
| NSS |
1 |
| DIO0 |
15 |
| Reset |
4 |
| SCK |
22 |
| MOSI |
23 |
| MISO |
19 |
| GND |
GND |
| 3v3 |
3v3 |
I would advise to search on google an advised pinout for rfm69 + esp32 and configure it this way, I cannot advise on this pinout unfortunately.
