LoRa OMG - how to use the display?
I am really new to starting with LoRa. Having 2Pcs LILYGO TTGO 868MHz SX1276 ESP32 LoRa 0.96 Inch OLED Display bluetooth WIFI Module IOT Development Board. They worked out of the box with displays showing sent and received message “hello”
I have now flashed the receiver with LoRa OMG and it works fine, publishing MQTT messages to my broker, no problems but display is black. Now I wanted to experiment a little with using the display so I downloaded and added SSD1306 library to the OMG project, tried to add some code to ZgatewayLORA.ino but no success, display is still black.
Do you have hints what I can try more?
Here my modified ZgatewayLORA.ino
  OpenMQTTGateway  - ESP8266 or Arduino program for home automation
   Act as a wifi or ethernet gateway between your 433mhz/infrared IR/BLE signal  and a MQTT broker
   Send and receiving command by MQTT
  This gateway enables to:
 - receive MQTT data from a topic and send LORA signal corresponding to the received MQTT data
 - publish MQTT data to a different topic related to received LORA signal
    Copyright: (c)Florian ROBERT
    This file is part of OpenMQTTGateway.
    OpenMQTTGateway is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenMQTTGateway is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>.
#include "User_config.h"
#ifdef ZgatewayLORA
#  include <LoRa.h>
#  include <SPI.h>
#  include <Wire.h>
#  include "SSD1306Wire.h"
#  include "images.h"
SSD1306Wire display(0x3c, SDA, SCL);
void setupLORA() {
  pinMode(16,OUTPUT);
  digitalWrite(16, LOW);    // set GPIO16 low to reset OLED
  delay(50);
  digitalWrite(16, HIGH); // while OLED is running, must set GPIO16 in high、
  SPI.begin(LORA_SCK, LORA_MISO, LORA_MOSI, LORA_SS);
  LoRa.setPins(LORA_SS, LORA_RST, LORA_DI0);
  if (!LoRa.begin(LORA_BAND)) {
    Log.error(F("ZgatewayLORA setup failed!" CR));
    while (1)
  display.init();
  display.flipScreenVertically();
  LoRa.receive();
  Log.notice(F("LORA_SCK: %d" CR), LORA_SCK);
  Log.notice(F("LORA_MISO: %d" CR), LORA_MISO);
  Log.notice(F("LORA_MOSI: %d" CR), LORA_MOSI);
  Log.notice(F("LORA_SS: %d" CR), LORA_SS);
  Log.notice(F("LORA_RST: %d" CR), LORA_RST);
  Log.notice(F("LORA_DI0: %d" CR), LORA_DI0);
  Log.trace(F("ZgatewayLORA setup done" CR));
void LORAtoMQTT() {
  int packetSize = LoRa.parsePacket();
  if (packetSize) {
    StaticJsonBuffer<JSON_MSG_BUFFER> jsonBuffer;
    JsonObject& LORAdata = jsonBuffer.createObject();
    Log.trace(F("Rcv. LORA" CR));
#  ifdef ESP32
    String taskMessage = "LORA Task running on core ";
    taskMessage = taskMessage + xPortGetCoreID();
    //trc(taskMessage);
#  endif
    String packet;
    packet = "";
    for (int i = 0; i < packetSize; i++) {
      packet += (char)LoRa.read();
    LORAdata.set("rssi", (int)LoRa.packetRssi());
    LORAdata.set("snr", (float)LoRa.packetSnr());
    LORAdata.set("pferror", (float)LoRa.packetFrequencyError());
    LORAdata.set("packetSize", (int)packetSize);
    LORAdata.set("message", (char*)packet.c_str());
    display.clear();
    display.setFont(ArialMT_Plain_10);
    display.setTextAlignment(TEXT_ALIGN_LEFT);
    display.drawString(0 , 15 , "Ready to Receive");
    display.display();
    pub(subjectLORAtoMQTT, LORAdata);
    if (repeatLORAwMQTT) {
      Log.trace(F("Pub LORA for rpt" CR));
      pub(subjectMQTTtoLORA, LORAdata);
#  ifdef jsonReceiving
void MQTTtoLORA(char* topicOri, JsonObject& LORAdata) { // json object decoding
  if (cmpToMainTopic(topicOri, subjectMQTTtoLORA)) {
    Log.trace(F("MQTTtoLORA json" CR));
    const char* message = LORAdata["message"];
    int txPower = LORAdata["txpower"] | LORA_TX_POWER;
    int spreadingFactor = LORAdata["spreadingfactor"] | LORA_SPREADING_FACTOR;
    long int frequency = LORAdata["frequency "] | LORA_BAND;
    long int signalBandwidth = LORAdata["signalbandwidth"] | LORA_SIGNAL_BANDWIDTH;
    int codingRateDenominator = LORAdata["codingrate"] | LORA_CODING_RATE;
    int preambleLength = LORAdata["preamblelength"] | LORA_PREAMBLE_LENGTH;
    byte syncWord = LORAdata["syncword"] | LORA_SYNC_WORD;
    bool Crc = LORAdata["enablecrc"] | DEFAULT_CRC;
    if (message) {
      LoRa.setTxPower(txPower);
      LoRa.setFrequency(frequency);
      LoRa.setSpreadingFactor(spreadingFactor);
      LoRa.setSignalBandwidth(signalBandwidth);
      LoRa.setCodingRate4(codingRateDenominator);
      LoRa.setPreambleLength(preambleLength);
      LoRa.setSyncWord(syncWord);
      if (Crc)
        LoRa.enableCrc();
      LoRa.beginPacket();
      LoRa.print(message);
      LoRa.endPacket();
      Log.trace(F("MQTTtoLORA OK" CR));
      pub(subjectGTWLORAtoMQTT, LORAdata); // we acknowledge the sending by publishing the value to an acknowledgement topic, for the moment even if it is a signal repetition we acknowledge also
    } else {
      Log.error(F("MQTTtoLORA Fail json" CR));
#  endif
#  ifdef simpleReceiving
void MQTTtoLORA(char* topicOri, char* LORAdata) { // json object decoding
    LoRa.beginPacket();
    LoRa.print(LORAdata);
    LoRa.endPacket();
    Log.notice(F("MQTTtoLORA OK" CR));
#  endif
#endif
Answer to myself, finally the display is awake, the code below works!! (currently just shows “Ready” but now I know how to continue)
#ifdef ZgatewayLORA
#  include <LoRa.h>
#  include <SPI.h>
#  include <Wire.h>
#  include "SSD1306.h"
SSD1306 display(0x3c, 4, 15);
void setupLORA() {
  pinMode(16,OUTPUT);
  delay(50);
    while (1)
  display.init();
  LoRa.receive();
void LORAtoMQTT() {
  if (packetSize) {
#  ifdef ESP32
    //trc(taskMessage);
#  endif
    String packet;
    packet = "";
    display.clear();
    display.drawString(0 , 15 , "Ready");
    display.display();
    if (message) {
      if (Crc)
        LoRa.enableCrc();
      LoRa.beginPacket();
      LoRa.endPacket();
    } else {
#  endif
    LoRa.beginPacket();
    LoRa.endPacket();
#  endif
#endif
Cool ! If you want an example about how to implement board specific functions you can take a look to M5Stack board implementation :
Adding a ZboardTTGO.ino could be a good option associated with a config_TTGO.h
Thank you very much!!
Everything now works really well. I have the need I would like to display some data that I entered into the initial setup/configuration screen. Like if I enter name of gateway. In what variable can I reach it? Assume I am in ZgatewayLORA.ino and put in a line like
 display.drawString(0 , 45 , variableXXX);
where variableXXX should be the variable that holds the actual name of the gateway. Trying Gateway_Name just gives the “hardcoded” name
Did you try it lower case gateway_name ?
Excellent, works fine!!
Here you can see how I use your great OMG in Node-RED:
Thank you very much,
Best regards, Walter
Here is something that does a little more. Might follow @1technophile’s idea and move it out to a Zxxboard.ino later.
#ifdef ZgatewayLORA
#  include <LoRa.h>
#  include <SPI.h>
#  include <Wire.h>
#  include <Adafruit_GFX.h>
#  include <Adafruit_SSD1306.h>
//#  include "images.h"
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RST);
 //packet packet_counter
 int packet_counter = 0;
void setupLORA() {
  //Reset OLED Display via softare
  pinMode(OLED_RST, OUTPUT);
  digitalWrite(OLED_RST, LOW);
  delay(20);
  digitalWrite(OLED_RST, HIGH);
    //initialize OLED
  Wire.begin(OLED_SDA, OLED_SCL);
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3c, false, false)) { // Address 0x3C for 128x32
    Serial.println(F("SSD1306 allocation failed"));
     for(;;); // Don't proceed, loop forever
 // display.init();
 // display.flipScreenVertically();
 // display.setFont(ArialMT_Plain_10);
  Log.notice(F("Display Initialization Successful" CR));
  display.clearDisplay();
  display.setTextColor(WHITE);
  display.setTextSize(1);
  display.setCursor(0,0);
  display.print(Gateway_Name);
  display.display();
  delay(20);
  Log.notice(F("display Load Done" CR));
    display.print("LoRa Setup Failed");
    display.display();
    while (1)
  LoRa.receive();
void LORAtoMQTT() {
  if (packetSize) {
    StaticJsonDocument<JSON_MSG_BUFFER> jsonBuffer;
    JsonObject LORAdata = jsonBuffer.to<JsonObject>();
#  ifdef ESP32
    //trc(taskMessage);
#  endif
    String packet;
    packet = "";
    LORAdata["rssi"] = (int)LoRa.packetRssi();
    LORAdata["snr"] = (float)LoRa.packetSnr();
    LORAdata["pferror"] = (float)LoRa.packetFrequencyError();
    LORAdata["packetSize"] = (int)packetSize;
    LORAdata["message"] = (char*)packet.c_str();
    display.println("LORA Receiver");
    display.setCursor(0,20);
    display.print("LoRa packet Received");
    display.setCursor(0,30);
    display.print("Packets Published:");
    display.setCursor(50,45);
    display.print(packet_counter);
    display.display();
    packet_counter++;
    if (message) {
      if (Crc)
        LoRa.enableCrc();
      LoRa.beginPacket();
      LoRa.endPacket();
    } else {
#  endif
    LoRa.beginPacket();
    LoRa.endPacket();
#  endif
#endif
