Hello OpenMQTT Gateway community,
I’m trying to use a LoRa32 V2.1_1.6 with 868,300 MHz to receive data from a Bresser 5 in 1 weather station.
The screen reports:
- OMG Logo
- Wifi connected
- URL…
- MQTT connected
- SYS MQTT
- Then it receives a message, and reboots back to the OpenMQTTGateway logo and repeats the process.
But it’s not the white logo from the beginning, it’s only the black background image.
I’m using an own build based on the latest commit with monitor_filters = esp32_exception_decoder enabled. The build is lilygo-rtl_433-fsk.
The log shows only the same lines every time:
N: type: null
N: [ OMG->MQTT ] topic: home/OMG_lilygo_rtl_433_ESP_FSK/RTL_433toMQTT/Bresser-6in1/0/1146327701 msg: {"model":"Bresser-6in1","id":1146327701,"channel":0,"battery_ok":1,"temperature_C":18,"humidity":79,"sensor_type":1,"wind_max_m_s":0,"wind_avg_m_s":0,"wind_dir_deg":270,"uv":0,"startup":1,"flags":0,"mic":"CRC","protocol":"Bresser Weather Center 6-in-1, 7-in-1 indoor, soil, new 5-in-1, 3-in-1 wind gauge, Froggit WH6000, Ventus C8488A","rssi":-66,"duration":34996}
The Problem is also that I am receiving two devices.
"model": "Bresser-6in1",
"id": 1146327701,
"channel": 0,
"battery_ok": 1,
"temperature_C": 17.9,
"humidity": 80,
"sensor_type": 1,
"wind_max_m_s": 0.6,
"wind_avg_m_s": 0.6,
"wind_dir_deg": 270,
"uv": 0,
"startup": 1,
"flags": 0,
"mic": "CRC",
"protocol": "Bresser Weather Center 6-in-1, 7-in-1 indoor, soil, new 5-in-1, 3-in-1 wind gauge, Froggit WH6000, Ventus C8488A",
"rssi": -67,
"duration": 34996
"model": "LaCrosse-TX29IT",
"id": 8,
"battery_ok": 1,
"newbattery": 0,
"temperature_C": 17.7,
"mic": "CRC",
"protocol": "LaCrosse TX29IT, TFA Dostmann 30.3159.IT Temperature sensor",
"rssi": -88,
"duration": 3996
The uptime is going up, maybe it’s not even a reboot. Maybe the esp is cycling between a device that has view and one that not. But the reboots are way faster than the sensors are sending the data.
"uptime": 495,
"version": "version_tag",
"disc": true,
"ohdisc": false,
"env": "lilygo-rtl_433-fsk",
"freemem": 115928,
"mqttp": "1883",
"mqtts": false,
"mqttv": false,
"msgprc": 52,
"msgblck": 0,
"msgrcv": 52,
"maxq": 4,
"cnt_index": 0,
"minmem": 47132,
"tempc": 54.44,
"freestck": 4396,
"powermode": -1,
"eth": false,
"rssi": -47,
"SSID": "Connection Failed",
"BSSID": "B0:F2:08:24:B6:3F",
"ip": "192.168.10.45",
"mac": "90:15:06:C9:9B:30",
"modules": [
"LilyGo_SSD1306",
"WebUI",
"rtl_433"
It’s my first day with OpenMQTT Gateway, what I can try and add to the topic?
