I followed this description:
https://docs.openmqttgateway.com/upload/arduino-ide.html
Using
LED_RECEIVE=15
TRIGGER_GPIO=37
SLEEP_BUTTON=38
DINPUT_GPIO=39
I get:
Arduino: 1.8.13 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Minimal SPIFFS (Large APPS with OTA), 921600, None"
In file included from /Users/uli/Downloads/OpenMQTTGateway-0.9.5/main/main.ino:28:0:
User_config.h:211:1: error: 'LED_RECEIVE' does not name a type
LED_RECEIVE=15
/Users/uli/Downloads/OpenMQTTGateway-0.9.5/main/main.ino: In function 'void loop()':
main:1195:18: error: 'timer_sys_measures' was not declared in this scope
if (now > (timer_sys_measures + (TimeBetweenReadingSYS * 1000)) || !timer_sys_measures) {
Multiple libraries were found for "FreeRTOS.h"
Used: /Users/uli/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/BLE
Not used: /Applications/ExternalApplications/Hardware/Arduino/Arduino.app/Contents/Java/libraries/NimBLE-Arduino
Multiple libraries were found for "WiFi.h"
Used: /Users/uli/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/WiFi
Not used: /Applications/ExternalApplications/Hardware/Arduino/Arduino.app/Contents/Java/libraries/WiFi
Multiple libraries were found for "SD.h"
Used: /Users/uli/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/SD
Not used: /Applications/ExternalApplications/Hardware/Arduino/Arduino.app/Contents/Java/libraries/SD
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Using
#define LED_RECEIVE 15
#define TRIGGER_GPIO 37
#define SLEEP_BUTTON 38
#define DINPUT_GPIO 39
I get:
In file included from /Applications/ExternalApplications/Hardware/Arduino/Arduino.app/Contents/Java/libraries/NimBLE-Arduino/src/FreeRTOS.cpp:8:0:
/Applications/ExternalApplications/Hardware/Arduino/Arduino.app/Contents/Java/libraries/NimBLE-Arduino/src/FreeRTOS.h:72:31: error: 'RingbufferType_t' has not been declared
Ringbuffer(size_t length, RingbufferType_t type = RINGBUF_TYPE_NOSPLIT);
/Applications/ExternalApplications/Hardware/Arduino/Arduino.app/Contents/Java/libraries/NimBLE-Arduino/src/FreeRTOS.cpp:268:39: error: 'RingbufferType_t' has not been declared
Ringbuffer::Ringbuffer(size_t length, RingbufferType_t type) {
/Applications/ExternalApplications/Hardware/Arduino/Arduino.app/Contents/Java/libraries/NimBLE-Arduino/src/FreeRTOS.cpp: In constructor 'Ringbuffer::Ringbuffer(size_t, int)':
/Applications/ExternalApplications/Hardware/Arduino/Arduino.app/Contents/Java/libraries/NimBLE-Arduino/src/FreeRTOS.cpp:272:48: error: invalid conversion from 'int' to 'ringbuf_type_t' [-fpermissive]
m_handle = ::xRingbufferCreate(length, type);
In file included from /Applications/ExternalApplications/Hardware/Arduino/Arduino.app/Contents/Java/libraries/NimBLE-Arduino/src/FreeRTOS.h:14:0,
/Users/uli/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/tools/sdk/include/esp_ringbuf/freertos/ringbuf.h:69:17: note: initializing argument 2 of 'void* xRingbufferCreate(size_t, ringbuf_type_t)'
RingbufHandle_t xRingbufferCreate(size_t xBufferSize, ringbuf_type_t xBufferType);
exit status 1
Error compiling for board M5Stack-Core-ESP32.
