Makerfabs LoRa gateway support
Hi all, I just ordered a LoRa gateway from Makerfabs (along with a bunch of their soil moisture sensor), link: MaESP ESP32 Lora Gateway | Makerfabs
It can either be a Wroom or Wrover ESP32 (I picked a Wrover).
I don’t see it in the list of supported boards though. Has anyone ever looked into this one? Would it be hard for a neophyte to add support for it? I delved a bit into esphome already and am not afraid to get my hands dirty.
I have a pretty extensive smart home anyway, but these are my first LoRa devices and it would seem OMG it’s the best way to get them into home assistant.
You need to take a look at their documentation, identify the different components and how they are linked with the ESP32.
If the components have already a module in OMG, it will be mainly about pin mapping and configuration = defining an environment into the environment.ini file, and testing that it works well.
If it is not the case this is more complex as it will require development
Thanks! They are using standard SX127x LoRa modules that are supported by the arduino-lora library, so it shouldn’t be too hard indeed. Gonna take a look as soon as I receive the gateway, PR incoming.
Default are ttgo pins.
You may need change pins
I’ve got the gateway working locally, I need to make it pretty so ttgo and makerfabs can coexist before I make a PR.
I’m now trying to connect my moisture sensors, I do seem to pick up their messages, but they are hex encoded and it’s unclear how I should decode them. Do I do that on the OMG side, or the Home Assistant side?
I tried decoding them manually using a js library, but it only partially decoded stuff, I still couldn’t see the data.
The moisture sensors are standard AHT10 sensors, I do see some code related to them in OMG but it’s not clear how I should use it.
Hi @alucryd
Have you added
${libraries.ahtx0}
to your lib_deps, and
'-DZsensorAHTx0="AHTx0"'
to your build_flags in your custom environment?
Then hook the AHT10 sensors up following the pinout table at
and you should get the decoded messages as described at
Hope this helps
He says before realising that the AHTx0 isn’t included in the table :stuck_out_tongue_winking_eye:
Best to follow the pinout in config_AHTx0.h
Hi @DigiH, I was under the impression that this was for when you directly connect the sensor to the ESP, but in my case the sensor is broadcasting messages via LoRa. They are prebuilts from Makerfabs: Lora Temperature/ Humidity/ Soil Moisture Sensor V3 | Makerfabs
I need to decode hex messages like this one:
9151DDFE267EDD6EBF550137195529A4655E5DCCEBE16D2FC9BA5E5FA4A9F6CBCD1F5BBA7B37B3B9ADF55D4550B9822E0651043D1EB25851BA33D76D19D67BB3A27470AC7BFA92FEFC57DC2D46F1E0FCBC8EFD2DBF5EE28D70CAD79A32EA12848D508AE64D94C1B05267377C
Correct, sorry, then I misread you, assuming you had them connected directly to an ESP running OMG.
These being open source hardware and software devices, I assume you have the details about the properties’ hex encoding. Any link to the firmware?
Alternatively you could try your own reverse engineering if you have another option to get the actual values off the devices/
If you implement this in OpenMQTTGateway or Home Assistant is really up to you preference. Implementing it in OMG would also allow you to create a discovery for them, so HA integration would be simpler if you have several of them.
Ok, seems to be
Then I’m not sure why you’re not getting the hex messages and not the stated described message, which doesn’t seem to be hex encoded either from your example :frowning:
Been making progress, the hex data must be coming from devices I don’t own. Turns out OMG discards the data coming from the sensors as it’s not JSON :confused: Not sure adapting OMG to parse the terrible format that comes out of these sensors is the way to go. Ordered a USB 2 UART adapter so I can rewrite the firmware of these sensors to output JSON data instead.
It’s LoraWAN? You may need change firmware
Did you get this up and running with Homeassistant. I am looking at purchasing the same hardware and was wondering if you could share your final setup. Thanks.
@dormani I did, ended up modifying the moisture sensor firmwares to send JSON data that can be read directly by OMG. Also simplified the firmware code, I still have one thing to fix, the moisture in percentage can go above 100, I wrote the formula based on their documentation, so either I made a mistake or the doc is wrong. I’ll push the final firmware to github when I find some time to fix it.
Many thanks for replying to me on this. I received my sensors a couple of days ago along with the Lora receiver from Makerfabs. If you could get back to me with the coding I would really appreciate it. Will save me a lot of time starting from scratch. All the best.
@alucryd As you must be busy, could you please provide me with the firmware that you have for producing the JSON for the moisture sensors. I will have a look and see if I can make the changes required to fix the moisture level percentage. I am at a stage where I want to progress this project to getting the data into Homeassistant. Have only 2 soil sensors but want to purchase more when I have this up and running before summer comes here in Australia. Many thanks.
