Meshtastic LoRa mesh?
Hi is it feasible to run your software on a Meshtastic supported device https://meshtastic.org/docs/hardware/tbeam-hardware
And send data over the LoRa mesh network provided by their project?
Intro to the project if you’re unfamiliar:
Are you thinking on having a Lora mesh to MQTT and MQTT to Lora mesh gateway ?
It is discussed here:
https://meshtastic.org/docs/software/other/mqtt
any news on this? i would like to create a LoRa node that also comunicate via mqtt
Regarding the topic of this thread, having a Meshtastic bidirectional gateway with MQTT, it seems already implemented. See below:
If you are looking for a LORA to MQTT gateway, this is also implemented into OpenMQTTGateway
