Hi if i update my miflora devices to current f/w with the xiaomi phone app (bluestacks?) will they still work with older pair/query diy solutions such as what i currently use the contrib-xiaomi-ble node https://github.com/eschava/node-red-contrib-xiaomi-ble
when i first started using these sensors i read dire warnings against even looking at its associated phone app lest it corrupt the device and close it to diy use.
I would suck it and see but thats risking a valuable sensor…
also some of my sensors were intended for the ‘domestic’ market and are not intended to work with the ‘international’ app iirc?
Ideally i could use this spectacular tool to query the public metrics on a super regular basis to feed real time systems and use the ‘old’ connect/query approach once a day to retrieve battery stats…
I take it from the short response you expect that the sensor metrics should already be coming through?
one fact that may or may not be relevant - all sensors are currently dry not in plant pots if that effects what data is publicly advertised or not idk, im just sure if i omitted that detail it would be bloody crucial
Im using V0.9.4 as version 0.9.5 would not retain any credentials provided through its access point interface.
