Modbus RTU Gateway development
First of all - thank you for such a great project :slight_smile: !
Currently, I’m looking for the best way to deploy a MQTT ↔ MODBUS RTU gateway. I found OpenMQTTGateway and thought it sounds perfect - but to modbus support yet.
Instead of hard coding for a single project, I would rather develop and contribute to a project like OMG since most of the components such as MQTT and browser UI are already integrated.
However, there are some prerequisites I have on my current project and I wonder if they can be met by OMG. I assume yes, but want to rather ask now before getting deeper into the project:
  • ESP32 support (obviously yes)
  • wired ethernet support
  • very fast MQTT ↔ MODBUS transition once the gateway exists (milliseconds)
Can those requirements be met?
And as the final question: Is there interest at all in extending OMG to protocols like modbus or is that a direction which is out of focus of the project?
edit: clarify Mobus RTU
hello,
Thanks for considering OMG for your project, a MODBUStoMQTT gateway is interesting and could be added to the project. TO answer to your questions:
  • ESP32 support (obviously yes) → I confirm
  • wired ethernet support → yes already supported with some boards like the Olimex ones
    What do you mean by “Once the gateway exists” ?
so I guess it’s a matter of wether the phy is supported by the ESP?
once the software is written - I’m sorry that sounded strange :upside_down_face:
The reason for asking this question is wether there are any known limiting factors on latency within OMG - without reviewing the code. Of course not counting serial IO / modbus latency.
Also, speed (latency) and reliability are the reasons for choosing wired ethernet over wifi.
Yes indeed and having a proper driver for the ethernet component
I would propose testing it, as we never had such requirements for “milliseconds”
All right.
I will try to dig into it once I get the hardware. I ordered some small chinese parts which have an ESP32, ethernet (100Mbit RJ45) and RS-485 build right on it.
I’m quite excited - thank you :slight_smile:
There is any work in “MODBUStoMQTT” ?
