Hello coders
I have one Gateway with DHT config on ESP8266 and everything works fine…
Then I was upload same sketch ( I changed topic home to topic warehouse and I changed Base_Topic Gateway_Name “/DHTtoMQTT/dht1” to Base_Topic Gateway_Name “/DHTtoMQTT/dht2”…
When I was restart HASSIO on RP3… both sensors have UNKNOWN value…
After 5-10 minutes … one of sensors write correct value… after 15 minutes second sensor write correct value…
After hour… both sensors write same values … without changes
On serial monitor:
MQTT connection…
Connected to broker
- correct TEMP and HUM
Any ideas ? Thanks a lot
