Here is the part I have changed:
#define OMG_VERSION “0.8.1”
/-------------DEFINE YOUR MQTT PARAMETERS BELOW----------------/
//MQTT Parameters definition
//#define mqtt_server_name “www.mqtt_broker.com” // instead of defining the server by its IP you can define it by its name, uncomment this line and set the correct MQTT server host name
char mqtt_user[20] = “mqtt”; // not compulsory only if your broker needs authentication
char mqtt_pass[20] = “xxxxx”; // not compulsory only if your broker needs authentication
char mqtt_server[40] = “192.168.0.34”;
char mqtt_port[6] = “1883”;
#define Gateway_Name “OpenMQTTGateway”
#define Base_Topic “home/”
#define version_Topic Base_Topic Gateway_Name “/version”
#define will_Topic Base_Topic Gateway_Name “/LWT”
#define will_QoS 0
#define will_Retain true
#define will_Message “Offline”
#define Gateway_AnnouncementMsg “Online”
/-------------DEFINE YOUR NETWORK PARAMETERS BELOW----------------/
//#define ESPWifiManualSetup true //uncomment you don’t want to use wifimanager for your credential settings on ESP
#define WifiManager_password “your_password”
//#define MDNS_SD //uncomment if you want to use mdns for discovering automatically your ip server, please note that MDNS with ESP32 can cause the BLE to not work
//#define cleanFS true //uncomment if you want to clean the ESP memory and reenter your credentials
#define maxMQTTretry 4 //maximum MQTT connection attempts before going to wifi setup
//set minimum quality of signal so it ignores AP’s under that quality
#define MinimumWifiSignalQuality 8
// Update these with values suitable for your network.
#if defined(ESP32) || defined(ESPWifiManualSetup) // for nodemcu, weemos and esp8266
#define wifi_ssid “wifi ssid”
#define wifi_password “wifi password”
#else // for arduino + W5100
const byte mac[] = { 0x60, 0x01, 0x94, 0x69, 0x38, 0xC1 }; //W5100 ethernet shield mac adress
#endif
const byte ip[] = { 192, 168, 0, 37 }; //ip adress
const byte gateway[] = { 0, 0, 0, 0 }; //ip adress, if first value is different from 0 advanced config network will be used and you should fill gateway & dns
const byte Dns[] = { 0, 0, 0, 0 }; //ip adress, if first value is different from 0 advanced config network will be used and you should fill gateway & dns
const byte subnet[] = { 255, 255, 255, 0 }; //ip adress
/-------------DEFINE YOUR OTA PARAMETERS BELOW----------------/
#define ota_hostname Gateway_Name
#define ota_password “OTAPASSWORD”
#define ota_port 8266
/-------------DEFINE PINs FOR STATUS LEDs----------------/
#define led_receive 40
#define led_send 42
#define led_error 44
// VCC ------------D|-----------////\ ----------------- Arduino PIN
// LED Resistor 270-510R
/-------------DEFINE THE MODULES YOU WANT BELOW----------------/
//Addons and module management, comment the Z line
#define ZgatewayRF “RF” //ESP8266, Arduino, ESP32
//#define ZgatewayRF315 “RF315” //ESP8266, Arduino, ESP32
//#define ZgatewayBT “BT” //ESP8266, Arduino, ESP32
//#define ZgatewaySRFB “SRFB” // Sonoff RF Bridge
//#define Zgateway2G “2G” //ESP8266, Arduino, ESP32
//#define ZactuatorONOFF “ONOFF” //ESP8266, Arduino, ESP32, Sonoff RF Bridge
//#define ZsensorINA226 “INA226” //ESP8266, Arduino, ESP32
//#define ZsensorHCSR501 “HCSR501” //ESP8266, Arduino, ESP32, Sonoff RF Bridge
//#define ZsensorADC “ADC” //ESP8266, Arduino, ESP32
//#define ZsensorBH1750 “BH1750” //ESP8266, Arduino, ESP32
//#define ZsensorTSL2561 “TSL2561” //ESP8266, Arduino, ESP32
//#define ZsensorBME280 “BME280” //ESP8266, Arduino, ESP32
//#define ZsensorDHT “DHT” //ESP8266, Arduino, ESP32, Sonoff RF Bridge
//#define ZgatewayRFM69 “RFM69” //ESP8266, Arduino, ESP32
