I’m sure you’ve also already tried the RF2 option
No, i havn’t as i didn’t assemble this device myself. Is there anyway of checking or querying the device to see what RF library it is using? Can i tell via watching the mqtt explorer payloads?
Though doing a search for the ILumos switches does indicate that they might be problematic
Yup saw this a year or so ago, to me it simply looks like someone wasn’t happy with the broadlinks functionality at controlling the switches with RF so took it apon themselves to sharpen up the RF implementation themselves. But it dosn’t disprove that these should work with 433mhz.
Any ideas?
As long as you’re aware that it is highly illegal in Europe to privately use the 315 MHz band for transmissions, as it is purely restricted to military communications use
I’m not using the 315mhz band and i’m not near any airports
The decision was purely around if there’s a choice of 2… I want that the dual band one!.
I’m still up for any ideas to try as the broadlink works fine with the switches so i believe this is a configuration thing on my OMG gateway. Is it possible to run all RF libraries simultaneously on an OMG gateway or can you only run one at a time?
Lastly, Is there an easy Over-the-air updater to install the newest version of OMG gateway using the built in wifi/ap of the OMG gateway? I was hoping to not have to set up the project in full on my pc to update it as it is now installed…Anyone?
