I just got some Inkbir IBS-TH2 sensors, temperature only models. I have some temp/humidity sensors already working. The new sensors show up in the mqtt BTtoMQTT topic, but no temperature data. They don’t seem to be recognized as Inkbird devices.
I think the problem is that the code is doing a strcmp for “sps” and these guys have “tps”
the “offending” code
if (strcmp(name, “sps”) == 0) {
The mqtt messages
home/home_presence/OpenMQTTGateway_ESP32_BLE {“id”:“49:42:07:00:06:CD”,“name”:“tps”,“manufacturerdata”:“e308000000e3b66406”,“rssi”:-92,“distance”:27.75274}
home/OpenMQTTGateway_ESP32_BLE/BTtoMQTT/4942070006CD {“id”:“49:42:07:00:06:CD”,“name”:“tps”,“rssi”:-92,“distance”:27.75274}
I haven’t tried yet, but I’m thinking the fix will be something like:
if (strcmp(name, “sps” ) | strcmp(name, “tps”)) == 0) {
Thank you for the offer of help. After I did the magick incantation and twirled around 3 times (aka did the proper steps completely and in order to flash the newer firmware) the sensors are recognized properly as TH1 and TH2.
the devices all have TH2 printed on them, but that is a minor inconvenience. alll is well here.
Hi, where did you find the steps to flash the Inkbird IBS-TH2 firmware? Maybe I can get the tps sensor to work as sps sensor with humidity included since its likely the same hardware.
