New sensor proposition ZsensorGPIOMultiInput
I am new on this forum sorry if I do something wrong in this topic.
So I am building an openmqttgateway, and I would like to make something original with it. I would like it to be a decorative object and behave like a kind of controll pannel.
So I needed a simple way to connect multiple buttons. After looking at the code I haven’t found anything matching with my needs. I wanted something like GpioInputSensor but with up to 8 buttons.
So I decided to code my own senser ZsensorGPIOMultiInput wich behave like ZsensorGPIOInput but can manage up to 8 buttons.
Yesterday I tested all my code and everythings works pretty good.
So my questions are: Why is there nothing like this is in current code? Should I propose my code to review or is there a reason why it does not exist?
Thank you !
Hi @Akrobate,
this sounds very interesting.
Ideally this could be all merged into the original ZsensorGPIOInput, allowing 1-8 GPIO Inputs.
You might be the first to want such a use case :slight_smile: and please do propose a PR on GitHub with your changes for review.
Thanks for this!
Thank you for your answer,
I have just made a PR on the repository.
I decided to not enrich this existing sensor because of a specific behavour of the button
I don’t wanted to interfer with this:
#  if defined(TRIGGER_GPIO) && INPUT_GPIO == TRIGGER_GPIO
    if (reading == LOW) {
      if (resetTime == 0) {
        resetTime = millis();
      } else if ((millis() - resetTime) > 10000) {
        Log.trace(F("Button Held" CR));
        Log.notice(F("Erasing ESP Config, restarting" CR));
        setup_wifimanager(true);
    } else {
      resetTime = 0;
#  endif
And also I will maybe implement specific behaviour to publish message on long press on each of my inputs
Thanks for the PR,
This is used to reset ESP flash in case of bad credentials.
Maybe we could differentiate 3 types of press depending on length, or you could publish the press duration to have the logic at the controller level.
I think it would help to merge the code of those 2 sensor GPIO inputs.
