I have some troubles creating a custom pinout with use of a portable config file…
This is what I understood from (Option 3) Upload your configurations | OpenMQTTGateway v1.4.0
I created a file, named
bearforce_rf_env.ini
with following contents
; BEARFORCE
; see
; https://docs.openmqttgateway.com/upload/builds.html
[platformio]
default_envs = nodemcuv2-rf
[env:nodemcuv2-rf]
'-DGateway_Name="OMG-004"'
'-DRF_RECEIVER_GPIO=5'
'-DMQTT_USER="your_username"'
'-DMQTT_PASS="your_password"'
'-DMQTT_SERVER="mqtt.bearforce.org"'
Seems that some of this config is accepted (MQTT settings) but other aren’t (RF_RECEIVER_GPIO)
Is there something wrong with this config?
PS
I also added my wificonfig, but this is not accepted either
I als tried:
[env:nodemcuv2-rf]
'-DGateway_Name="OMG-003"'
-DRF_EMITTER_GPIO=3
-Dwifi_ssid=\"MY\\\-SSID\\\-2GHZ\"
-Dwifi_password=\"Mypassword2023\"
and
[env:nodemcuv2-rf]
'-DRF_EMITTER_GPIO=3'
'-Dwifi_ssid="MY-SSID-2GHZ"'
and
[env:nodemcuv2-rf]
'-Dwifi_password="Mypassword2023"'
But only the MQTT settings and gateway name are accepted. Wifi and GPIO settings are ignored.
Probably something wrong with syntax. Or my lack of knowledge…
Any help is appreciated!
Kind regards,
Bart
DigiH
February 17, 2023, 3:16pm
2
Hi @BartPlessers ,
what happens when you rename your custom environment definition to something like
[env:nodemcuv2-rf-bart]
as it very likely currently clashes with the default [env:nodemcuv2-rf] when building and uploading.
aha! will give that a try.
And what to do if I don’t want my custom environment? I just want to define some stuff in the [env:nodemcuv2-rf].
Is this possible?
DigiH
February 17, 2023, 3:23pm
4
BartPlessers:
Is this possible?
Sure, this is possible, but with each OMG update the default environment in environments.ini will be reset and you will have to reapply all the changes, while a custom bearforce_rf_env.ini you can just copy into the new OMG directory and you’re set.
still struggling with the syntax.
following seems not to work
[platformio]
default_envs = nodemcuv2-rf-bart
extends = nodemcuv2-rf
'-DGateway_Name="OMG-005"'
than I get an error
Error: Please specify platform for 'nodemcuv2-rf-bart' environment
also following doesn’t work
[platformio]
because my environment “nodemcuv2-rf-bart” is not adressed anywhere I suppose.
Can somebody provide me with a working example?
The only thing I want to achieve (for now) is
select RF
setting wifi SSID and passwd
setting custom GPIO
thanx in advance!
B
DigiH
February 17, 2023, 3:48pm
6
BartPlessers:
In the example
extends = env:nodemcuv2-pilight-bme280
missing env:
aaaaaaaaaaaaaaaaaaarghhhhhhhhhhhhhhhhhhh
learning curve…
DigiH
February 17, 2023, 3:53pm
8
And also in your custom env.ini you want your default_envs to have the name of your custom environment.
[platformio]
depending on how you build and upload it.
jihaaaaaa! Eternal fame:
; BEARFORCE
; see
[platformio]
extends = env:nodemcuv2-rf
${env:nodemcuv2-rf.lib_deps}
${env:nodemcuv2-rf.build_flags}
'-DGateway_Name="OMG-007"'
GPIO seems to work now
However, wifi settings seems not be be accepted.
Any tips?
I tried
'-Dwifi_ssid="BEARFORCE-N01-2GHZ"'
'-Dwifi_password="Password2023"'
and
-Dwifi_password=\"Password2023\"
and
-Dwifi_ssid=\"BEARFORCE\\\-N01\\\-2GHZ\"
has this something todo with capitals, hyphen, numbers in my config?
Or is there something els wrong?
grtz
B
DigiH
February 17, 2023, 4:37pm
10
Manual WiFi credentials also need
'-DESPWifiManualSetup=true'
then your
will work and you are all set with your custom portable env.ini
Ofcourse! stupid me.
I was confused: if you define wifi_ssid and wifi_password, the wifimanager will NOT start, but the settings are also NOT applied…
anyway, thanx a lot for your patience!
have a good weekend,
bart
