No MQTT results except version=v1.4.0
Just purchased and configured. I don’t see any MQTT results showing up from scans. Also, thought I would be able to get more info from the UI. Am I missing something? The ‘+’ button only allows blacklisting.
Thanks for your support!
Do you see sensors in the app ?
Can you see the app connected to your mqtt broker ?
Thanks for the reply. I’m getting two sensors in the front screen, but see lots of others in device browser. I kinda expected more between two locations I’ve run it from. Maybe I expected to be able to see more info about the discovered devices.
Which ones do you see in the device browser that you don’t see in the main display?
For information here is the list of compatible devices:
