Dear, I have a problem.
When starting the system (connecting power) everything is connected perfectly and I can receive signals without any inconvenience.
But after performing the first TX (MQTTto433) it would seem that the transmitter is sending noise and blocks the reception of all the signals (the transmission is done correctly and if I do another TX also it does it but it is as if at the end of sending the transmission the NodeMcu leaves sending noise to TX that invade the spectrum and block the RX), if I disconnect the power of the TX I can receive signals again.
I have connected the NodeMCU pins on the following pins:
#define RF_RECEIVER_PIN 0 // D3 on nodemcu // put 4 with rf bridge direct mod
#define RF_EMITTER_PIN 4 // RX on nodemcu if it doesn't work with 3, try with 4 (D2) // put 5 with rf bridge direct mod
The version I am using is:
/-------------------VERSION----------------------/
#define OMG_VERSION β0.9.1β
I hope I have been clear and see if you can help me with this problem.
Thank you!!!
