Hi
I started at openmqttgateway a few days ago, and I’m stuck with a problem.
I have a nodemcu configured with the hm-10 sensor on and configured.
In mqtt broker I have everything to communicate …
SDK:3.0.0-dev(c0f7b44)/Core:2.5.0=20500000/lwIP:STABLE-2_1_2_RELEASE/glue:1.1/BearSSL:6778687
mounting FS…
failed to mount FS
*WM: Adding parameter
*WM: server
*WM: port
*WM: user
*WM: pass
*WM:
*WM: AutoConnect
*WM: Connecting as wifi client…
*WM: Using last saved values, should be faster
scandone
scandone
state: 0 → 2 (b0)
state: 2 → 3 (0)
state: 3 → 5 (10)
add 0
aid 6
cnt
connected with MyNetwork_2.4Ghz, channel 11
dhcp client start…
ip:192.168.0.127,mask:255.255.255.0,gw:192.168.0.1
WM: Connection result:
WM: 3
WM: IP Address:
WM: 192.168.0.127
connected…yeey ![]()
saving config
failed to open config file for writing
{“mqtt_server”:“192.168.0.4”,“mqtt_port”:“1883”,“mqtt_user”:“openhabian”,“mqtt_pass”:"*********"}*WM: freeing allocated params!
OpenMQTTGateway mac:
DC:4F:22:58:CD:E5
OpenMQTTGateway ip:
192.168.0.127
1883
192.168.0.4
IR_EMITTER_PIN
16
IR_RECEIVER_PIN
2
ZgatewayIR setup done
RF_EMITTER_PIN
3
RF_RECEIVER_PIN
0
RF setup ok
ZgatewayBT HM1X setup done
MQTT_MAX_PACKET_SIZE
1024
Setup OpenMQTTGateway end
MQTT connection…
Connected to broker
pm open,type:2 0
I now have a BLE temperature sensor of xiaomi and wanted to add in openhab.
What do I have to do now?
How do I detect the xiaomi sensor?
How do I confirm that the sensor is sending and receiving bluetooth signal?
In integrating with openhab, as long as I get the topics in the broker I already know what to do.
Thank you
