NodeMCU + RFM69 - witch env module in platformio.ini?
Hi there all,
I just try to make work a NodeMCU module with a RFM69HC
I use this page step by step and put all pin from RFM module to the NodeMCU.
First of all I want to ask which is the path of the folder
where I must remove the RFM69_OTA.cpp and RFM69_OTA.h files.
Then I must uncomment in user_config the
#define ZgatewayRFM69
Now I just want to ask… in the platformio.ini witch env I must uncomment
in order to build all please ?
Thanks all
Denis
note that the current implementation with RFM69 support only other devices with RFM69.
There is no particular env defined for this you may take env:nodemcuv2-all-test and remove all the libraries and modules not related to RFM69.
Great… thanks a lot
Denis
