Hi there, need to setup my first OpenMQTT gateway. I have an existing April Brother gateway I have been using with their own firmware.
Has anyone flashed one of these with OpenMQTT in the past?
Any hints, issues I need to be aware off?
Hi !
Do you know if the usb connection enables a serial port ?
If yes it could be easily flashed. If no you would need to open it and share photo so that we see where you can connect an FTDI.
There is indeed a serial port to use with a classic USB ESP programmer (mine has a corresponding pin header)
April Brother Wiki (aprbrother.com)
Which firmware would you recommend to use? I have one with ESP-WROOM-32E + Ethernet
This gateway is not going to work with OMG due to the use of this:
OMG rely on the ESP32 BLE and doesn’t support NRF52832
