Not able to send any RF data
Hi guys,
first of all thank you for your great work. I am using the gateway in combination with Openhab and it works great!
Unfortunately I have a problem that I could not solve, although I tried different things and studied all the instructions on git.
I also checked the transmitter on a raspberry pi it it is working fine.
My board is a NodeMCU V3. Receiving a signal is no problem. My pin configuration in configRF.h is as follows:
#ifdef ESP8266
    #define RF_RECEIVER_PIN 4 // D3 on nodemcu
    #define RF_EMITTER_PIN 16 // RX on nodemcu if it doesn't work with 3, try with 4 (D2)
I also tried pin 3 (RX) but that didn´t work either.
I want to switch some plugs of different brands.If I press the button on the remote I receive the following code:
home/OpenMQTTGateway/433toMQTT
{"value":4543825,"protocol":1,"length":24,"delay":315}
I tried to send that one with the follwong command:
mosquitto_pub -t home/OpenMQTTGateway/MQTTto433 -m 4543825
but nothing happens.
This is only a received code I wanted to send but nothing happend:
{"value":5651376,"protocol":2,"length":24,"delay":724}
Is there anybody here who could give me a hint what I am doing wrong?
Thanks in advance!
Did you tried with Emitter on D2 = 4 and receiver on D3 = 0?
Yes I have already tried this constellation but unfortuately then the receive command doesn´t work either.
Are you using the beta? If so try version 0.8 - I ran into troubles with beta.
Yes you are right, I just downloaded the repository and not the release version 🤦
I will give a try this afternoon and see if it’s works now.
Also check @1technophile’s answer in my thread: RF commands not working in beta if you want the beta to be working.
I got the 0.8 working now and it shows up that the commands are sent out but my plugs are not switching.
Should there be a receive log in the console (on the serial interface) after I send out the data? Is the syntax I use correct?
Could you post what you get on the serial monitor?
Yes, sure:
That´s the command I sent out:
mosquitto_pub -t home/OpenMQTTGateway/commands/MQTTto433 -m 6086208
Hey I got a callback
08:08:59.940 -> MQTTtoRF dflt
Ack pub.
08:09:00.878 -> Storing signal
08:09:00.878 -> Min ind:
08:09:00.878 -> 6
08:09:00.878 -> store code :
08:09:00.878 -> 6086208/185588
08:09:00.878 -> Col: val/timestamp
08:09:00.878 -> 0:4539732/114850
08:09:00.878 -> 1:128/126879
08:09:00.878 -> 2:6086208/130594
08:09:00.878 -> 3:4539729/143612
08:09:00.878 -> 4:4539729/143748
08:09:00.878 -> 5:6086208/160702
08:09:00.878 -> 6:6086208/185588
08:09:00.878 -> 7:4539729/112064
08:09:00.878 -> 8:4539743/112332
08:09:00.878 -> 9:4543839/112364
08:09:00.878 -> 10:4543839/112389
08:09:00.878 -> 11:4539732/114684
08:09:00.878 -> Data stored
Another command:
mosquitto_pub -t home/OpenMQTTGateway/commands/PLSL_724/433_2/BITS_24 -m 5841296
08:14:20.814 -> RF Protocol:
08:14:20.814 -> 2
08:14:20.814 -> RF Pulse Lgth:
08:14:20.814 -> 724
08:14:20.814 -> MQTTtoRF usr par.
08:14:20.814 -> 2
08:14:20.814 -> 724
08:14:20.814 -> 24
MQTTtoRF ack pub.
08:14:21.986 -> 5841296
08:14:21.986 -> Hey I got a callback
08:14:21.986 -> Storing signal
08:14:22.033 -> Min ind:
08:14:22.033 -> 0
08:14:22.033 -> store code :
08:14:22.033 -> 5841296/506742
08:14:22.033 -> Col: val/timestamp
08:14:22.033 -> 0:5841296/506742
08:14:22.033 -> 1:128/126879
08:14:22.033 -> 2:6086208/130594
08:14:22.033 -> 3:4539729/143612
08:14:22.033 -> 4:4539729/143748
08:14:22.033 -> 5:6086208/160702
08:14:22.033 -> 6:6086208/185588
08:14:22.033 -> 7:2/335595
08:14:22.033 -> 8:6086208/458382
08:14:22.033 -> 9:6086208/458628
08:14:22.033 -> 10:5841296/485648
08:14:22.033 -> 11:5841296/494965
08:14:22.033 -> Data stored
In both cases the plugs do not switch.
Are there only certain protocols available? Or should resending the received signal work (like in Pilight raw)?
Maybe that is the reason why the plugs not switch.
When you listen your remote control signal did you get only one code or severals?
On MQTT only one. In the serial monitor it looks similar to send message I have posted.
This is what it shows on serial monitor:
Rcv. RF
21:02:51.822 -> isAduplicate?
21:02:51.822 -> Adv data RFtoMQTT
21:02:51.822 -> Sending RFtoMQTT
21:02:51.822 -> 5982064
21:02:51.822 -> RFtoMQTT OK
21:02:51.869 -> Storing signal
21:02:51.869 -> Min ind:
21:02:51.869 -> 3
21:02:51.869 -> store code :
21:02:51.869 -> 5982064/46894
21:02:51.869 -> Col: val/timestamp
21:02:51.869 -> 0:5440560/32668
21:02:51.869 -> 1:5774752/35696
21:02:51.869 -> 2:5774752/35961
21:02:51.869 -> 3:5982064/46894
21:02:51.869 -> 4:0/0
21:02:51.869 -> 5:0/0
21:02:51.869 -> 6:0/0
21:02:51.869 -> 7:0/0
21:02:51.869 -> 8:0/0
21:02:51.869 -> 9:0/0
21:02:51.869 -> 10:0/0
21:02:51.869 -> 11:0/0
21:02:51.869 -> Data stored
21:02:51.869 -> Rcv. RF
21:02:51.869 -> isAduplicate?
21:02:51.869 -> --don't pub. duplicate--
Rcv. RF
21:02:51.915 -> isAduplicate?
21:02:51.915 -> --don't pub. duplicate--
Did you tried these different messages:
5440560
5774752
5774752
5982064
No but I can try this tomorrow. Thanks in advance for you help.
Do you have an explanation what the values mean after the /?
One short OT question: Which channel do I have to subscribe if I want to get data from a DHT sensor? I uncommented the DHT sensor and plugged it to the NodeMcu but do not see any data.
yes this is the time of reception from omg start.
you have to uncomment zsensordht, verify the pins & dht model in config_DHT.h, and if you subscribe to :
mosquitto_sub -t +/# -v
you should see the values.
Sorry to bump an old thread but I’m having the same problem as the original post, I am unable to send RF at all and receive the same message as the OP.
I’m revisiting this great project after a few months as I have a new setup I need to integrate it with.
I re-assembled everything I had done when I was running 0.8 beta and had it working when I wrote this - GitHub - 1technophile/OpenMQTTGateway: MQTT gateway for ESP8266, ESP32, Sonoff RF Bridge or Arduino with bidirectional 433mhz/315mhz/868mhz, Infrared communications, BLE, Bluetooth, beacons detection, mi flora, mi jia, LYWSD02, LYWSD03MMC, Mi Scale, TPMS, BBQ thermometer compatibility, SMS & LORA..
But all I in the serial monitor get when trying to send is…
MQTTtoRF dflt
Ack pub.
Receiving is all fine I just can’t send.
I have tried the 0.9 .bin release, the 0.8 bin compiling the latest .ino release in IDE. all the same problem. I have changed pins, I’ve run it on a Wemos D1 mini and on a NodeMCU 1.0.
I have tested the transmitter module by plugging it into an Arduino and running the rc-switch send demo and it works fine.
I hope you can help :grinning:
If you try the basic examples from the rcswitch library folder do you get it working?
https://github.com/1technophile/OpenMQTTGateway/tree/development/lib/rc-switch/examples/SendDemo
Yup the rc-switch send demo works fine with my ESP and 433 module.
ok, could you post the command you are sending to the broker?
I had another go this morning compiling it from the latest .ino release in IDE and it is now working :smiley:
Before that I flashed the .bin file and it all went fine I opened up the AP and added my wifi credentials and my broker ip.
Oddly enough even tho I added my broker ip as 192.168.0.31 which it is, every time I flashed the .bin file it was trying to connect to 192.168.0.37 even tho I have never added those details or even had an MQTT broker on that ip :thinking:
Thanks for all your help and keep up the good work!
