I’m pretty much done with the ruuvi extension, but I’m struggling to get all parameters out. Somehow, my BT MQTT devices only display all parameters until “ruuvi-accy”. I’ve tried hard, but I can’t find the limit in the current code.
@1technophile could you give me a hand?
void ruuviDiscovery(char* mac) {
# define ruuviparametersCount 13
Log.trace(F("ruuviDiscovery" CR));
char* ruuvisensor[ruuviparametersCount][8] = {
{"sensor", "ruuvi-ver", mac, "version", jsonVer, "", "", ""},
{"sensor", "ruuvi-batt", mac, "battery", jsonBatt, "", "", "%"},
{"sensor", "ruuvi-tem", mac, "temperature", jsonTempc, "", "", "C"}, // remove for 0.9.6 release
{"sensor", "ruuvi-tempc", mac, "temperature", jsonTempc, "", "", "C"},
{"sensor", "ruuvi-tempf", mac, "temperature", jsonTempf, "", "", "F"},
{"sensor", "ruuvi-hum", mac, "humidity", jsonHum, "", "", "%"},
{"sensor", "ruuvi-pres", mac, "pressure", jsonPres, "", "", "hPa"},
{"sensor", "ruuvi-accx", mac, "acc_x", jsonAccx, "", "", "mG"},
{"sensor", "ruuvi-accy", mac, "acc_y", jsonAccy, "", "", "mG"},
{"sensor", "ruuvi-accz", mac, "acc_z", jsonAccz, "", "", "mG"},
{"sensor", "ruuvi-txpwr", mac, "tx_power", jsonTxpwr, "", "", "dBm"},
{"sensor", "ruuvi-seq", mac, "measurementSeqNum", jsonSeq, "", "", ""},
{"sensor", "ruuvi-mov", mac, "movementCounter", jsonMov, "", "", ""}
//component type,name,availability topic,device class,value template,payload on, payload off, unit of measurement
createDiscoveryFromList(mac, ruuvisensor, ruuviparametersCount);
