Olimex esp32 poe webinterface
Hi, First of all, thank you for hard work!
I have some olimex exp32 poe board for ble connections. Everything work as expected, but I dont have webinterface, to edit mqtt config after flash. Did I miss something or its only work with wifi types
BR,
O.
Hello !
The web interface is only available at first start unless you reset the gateway.
If you want to change config parameters we have implemented the capability to change wifi and mqtt parameters by mqtt in the developement branch :
