Hello together
i installed my MQTT Integration from new and have made the System to run now.
the OMG on Heltec Setup could not detect my switch remote as it has a strange protocoll
i sent the command via Remote and added these Lines with …/commands/MQTTtoRTL_433/… to the configuration.yaml
it results in i cannot send any command with the Heltec OMG.
mqtt:
switch:
- unique_id: SwitchB
state_topic: homeassistant/OpenMQTTGateway_heltec_rtl_433_ESP/RTL_433toMQTT/Smoke-GS558/21572
command_topic: homeassistant/OpenMQTTGateway_heltec_rtl_433_ESP/commands/MQTTtoRTL_433/Smoke-GS558/21572
#value_template: "{{ value_json.value }}"
payload_on: '{"model": "Smoke-GS558","id": 21572,"unit": 0,"learn": 0,"code": "8a8880","protocol": "Wireless Smoke and Heat Detector GS 558","rssi": -62,"duration": 308996}'
payload_off: '{"model": "Smoke-GS558","id": 21572,"unit": 0,"learn": 0,"code": "2a8880","protocol": "Wireless Smoke and Heat Detector GS 558","rssi": -62,"duration": 308996}'
Can anyone Tell me the correct Line or the Mistake i did here?
The HA Autodiscovery only detects the RSSI, but not that its a Switch Remote
Also in the newest HA Version the beginning of the yaml File is different than in the OMG Documentation
mqtt:
switch:
