Ok, Something is happening while adding WIFI settings too…
edit: trying with real and correct settings… below not correct.
Executing task: C:\Users\juha\.platformio\penv\Scripts\platformio.exe device monitor
--- Terminal on COM3 | 115200 8-N-1
--- Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable, send_on_enter, time
--- More details at https://bit.ly/pio-monitor-filters
--- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H
*wm:[2] <- HTTP Wifi
*wm:[2] Scan is cached 6879 ms ago
*wm:[1] 4 networks found
*wm:[2] AP: -82 KotiAP
*wm:[2] AP: -82 IoT-mqtt
*wm:[2] AP: -82 KotiAP5Ghz
*wm:[2] AP: -83 IoT
[E][WebServer.cpp:633] _handleRequest(): request handler not found
*wm:[2] <- Request redirected to captive portal
*wm:[2] Portal Timeout In 102 seconds
*wm:[2] <- HTTP WiFi save
*wm:[2] Parameters
*wm:[2] --------------------
*wm:[2] server: 192.168.1.11
*wm:[2] port: 1883
*wm:[2] user: mqtt
*wm:[2] pass: mqttmqtt
*wm:[2] secure:
*wm:[2] cert:
*wm:[2] name: OpenMQTTGateway
*wm:[2] topic: home/
*wm:[2] ota: OTAPASSWORD
*wm:[2] processing save
*wm:[2] Connecting as wifi client...
*wm:[2] setSTAConfig static ip not set, skipping
*wm:[1] Connecting to NEW AP: IoT-mqtt
*wm:[1] connectTimeout not set, ESP waitForConnectResult...
*wm:[2] Connection result: WL_CONNECTED
*wm:[1] Connect to new AP [SUCCESS]
*wm:[1] Got IP Address:
*wm:[1] 192.168.1.14
*wm:[2] [CB] _savewificallback calling
*wm:[2] shutdownConfigPortal
*wm:[0] [ERROR] disconnect configportal - softAPdisconnect FAILED
*wm:[2] restoring usermode STA
*wm:[2] wifi status: WL_CONNECTED
*wm:[2] wifi mode: STA
*wm:[2] configportal closed
*wm:[1] config portal exiting
"mqtt_server": "192.168.1.11",
"mqtt_port": "1883",
"mqtt_user": "mqtt",
"mqtt_pass": "mqttmqtt",
"mqtt_topic": "home/",
"gateway_name": "OpenMQTTGateway",
"mqtt_broker_secure": false,
"mqtt_broker_cert": "",
"mqtt_ss_index": 0,
"ota_server_cert": "",
"ota_pass": "OTAPASSWORD"
}[E][Preferences.cpp:472] getString(): nvs_get_str len fail: BTConfig NOT_FOUND
N: BT config loaded
N: BT sys: {
"bleconnect": false,
"interval": 0,
"activescan": true,
"intervalcnct": 3600000,
"onlysensors": false,
"hasspresence": false,
"presenceTopic": "presence/",
"presenceUseBeaconUuid": false,
"minrssi": -100,
"extDecoderEnable": false,
"extDecoderTopic": "undecoded",
"filterConnectable": false,
"pubadvdata": false,
"pubBeaconUuidForTopic": false,
"ignoreWBlist": false,
"btqblck": 0,
"btqsum": 0,
"btqsnd": 0,
"btqavg": 0
N: BT config loaded
N: BLE scans interval: 0
N: BLE connects interval: 3600000
N: Active BLE scan: true
N: minrssi: -100
N: Low Power Mode: 0
N: OpenMQTTGateway modules: ["BT"]
W: MQTT connection...
N: Connected to broker
N: Send on /SYStoMQTT msg {"uptime":64,"version":"v1.3.0","freemem":122388,"mqttport":"1883","mqttsecure":false,"tempc":45,"freestack":4284,"rssi":-87,"SSID":"IoT-mqtt","BSSID":"86:2A:A8:C7:5F:A1","ip":"192.168.1.14","mac":"78:21:84:C6:B8:2C","lowpowermode":0,"interval":0,"intervalcnct":3600000,"scnct":0,"modules":["BT"]}
N: Send on /BTtoMQTT msg {"bleconnect":false,"interval":0,"activescan":true,"intervalcnct":3600000,"onlysensors":false,"hasspresence":false,"presenceTopic":"presence/","presenceUseBeaconUuid":false,"minrssi":-100,"extDecoderEnable":false,"extDecoderTopic":"undecoded","filterConnectable":false,"pubadvdata":false,"pubBeaconUuidForTopic":false,"ignoreWBlist":false,"btqblck":0,"btqsum":0,"btqsnd":0,"btqavg":0}
N: Scan begin
N: Device detected: 7C:97:0D:52:19:47
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-83,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Device detected: 58:9D:DF:C1:9E:39
N: Send on /BTtoMQTT/589DDFC19E39 msg {"id":"58:9D:DF:C1:9E:39","rssi":-88,"txpower":12}
N: Found 2 devices, scan number 1 end
N: Scan begin
N: Device detected: CF:C2:BD:2A:8C:0E
N: Send on /BTtoMQTT/CFC2BD2A8C0E msg {"id":"CF:C2:BD:2A:8C:0E","rssi":-87}
N: Found 3 devices, scan number 2 end
N: Scan begin
N: Send on /BTtoMQTT/589DDFC19E39 msg {"id":"58:9D:DF:C1:9E:39","rssi":-92,"txpower":12}
N: Send on /BTtoMQTT/589DDFC19E39 msg {"id":"58:9D:DF:C1:9E:39","rssi":-86,"txpower":12}
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-82,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Found 3 devices, scan number 3 end
N: Device detected: FE:50:25:42:C8:A5
N: Scan begin
N: Send on /BTtoMQTT/FE502542C8A5 msg {"id":"FE:50:25:42:C8:A5","rssi":-97}
N: Send on /BTtoMQTT/CFC2BD2A8C0E msg {"id":"CF:C2:BD:2A:8C:0E","rssi":-94}
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-81,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Found 3 devices, scan number 4 end
N: Scan begin
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-93,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Found 2 devices, scan number 5 enNd:
N: Scan begin
N: Send on /BTtoMQTT/589DDFC19E39 msg {"id":"58:9D:DF:C1:9E:39","rssi":-93,"txpower":12}
N: Send on /BTtoMQTT/CFC2BD2A8C0E msg {"id":"CF:C2:BD:2A:8C:0E","rssi":-98}
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-79,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Found N: Device detect4ed: 58:9D:DF:C1:9E:39
devices, scan number 6 end
N: Scan begin
N: Send on /BTtoMQTT/589DDFC19E39 msg {"id":"58:9D:DF:C1:9E:39","rssi":-96,"txpower":12}
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-94,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Found 2 devices, scan number 7 end
N: Scan begin
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-77,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Found 3 devices, scan number 8 end
N: Scan begin
N: Send on /BTtoMQTT/589DDFC19E39 msg {"id":"58:9D:DF:C1:9E:39","rssi":-85,"txpower":12}
N: Found 2 devices, scan number 9 end
N: Scan begin
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-95,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Send on /BTtoMQTT/CFC2BD2A8C0E msg {"id":"CF:C2:BD:2A:8C:0E","rssi":-84}
N: Send on /BTtoMQTT/589DDFC19E39 msg {"id":"58:9D:DF:C1:9E:39","rssi":-91,"txpower":12}
N: Found 3 devices, scan number 10 end
N: Scan begin
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-98,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Send on /BTtoMQTT/589DDFC19E39 msg {"id":"58:9D:DF:C1:9E:39","rssi":-90,"txpower":12}
N: Found 3 devices, scan number 11 end
N: Scan begin
N: Found 2 devices, scan Nn: uDevice detectmed: 58:9D:DF:C1:9E:39
ber 12 end
N: Scan begin
N: Send on /BTtoMQTT/CFC2BD2A8C0E msg {"id":"CF:C2:BD:2A:8C:0E","rssi":-95}
N: Found 3 devices, scan number N13 end
N: Scan begin
N: Send on /BTtoMQTT/589DDFC19E39 msg {"id":"58:9D:DF:C1:9E:39","rssi":-95,"txpower":12}
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-91,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
NN: Device detected: 58:9D:DF:C1:9E:39
: Found 2 devices, scan number 14 end
N: Scan begin
N: Send on /BTtoMQTT/589DDFC19E39 msg {"id":"58:9D:DF:C1:9E:39","rssi":-94,"txpower":12}
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-96,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Send on /BTtoMQTT/FE502542C8A5 msg {"id":"FE:50:25:42:C8:A5","rssi":-94,"brand":"SwitchBot","model":"Meter (Plus)","model_id":"THX1/W230150X","tempc":19.5,"tempf":67.1,"hum":25,"batt":100}
N: Found 3 devices, scan number 15 end
N: Scan begin
N: Found 3 devices, scan number 16 end
N: Scan begin
N: Send on /BTtoMQTT/589DDFC19E39 msg {"id":"58:9D:DF:C1:9E:39","rssi":-97,"txpower":12}
N: Send on /BTtoMQTT/FE502542C8A5 msg {"id":"FE:50:25:42:C8:A5","rssi":-97,"brand":"SwitchBot","model":"Meter (Plus)","model_id":"THX1/W230150X","tempc":19.5,"tempf":67.1,"hum":25,"batt":100}
N: Found 3 devices, scNa: nDevice detect ed: 58:9D:DF:C1:9E:39
number 17 end
N: Scan begin
N: Found 2 devices, scan number 18 end
N: Scan begin
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-84,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Found 2 devices, scan number 19 end
N: Scan begin
N: Found 2 devices, scan number 20 endN
N: Scan begin
N: Send on /BTtoMQTT/589DDFC19E39 msg {"id":"58:9D:DF:C1:9E:39","rssi":-98,"txpower":12}
N: Found 3 devices, scan number 21 end
N: Scan begin
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-97,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Send on /BTtoMQTT/CFC2BD2A8C0E msg {"id":"CF:C2:BD:2A:8C:0E","rssi":-85}
N: Send on /BTtoMQTT/FE502542C8A5 msg {"id":"FE:50:25:42:C8:A5","rssi":-96,"brand":"SwitchBot","model":"Meter (Plus)","model_id":"THX1/W230150X","tempc":19.5,"tempf":67.1,"hum":25,"batt":100}
N: Found 3 devices, scan number 22 end
N: Scan begin
N: Found 3 devices, scan numNb: eDevice detectred: 58:9D:DF:C1:9E:39
23 end
N: Scan begin
N: Send on /BTtoMQTT/FE502542C8A5 msg {"id":"FE:50:25:42:C8:A5","rssi":-98}
N: Found 2 devices, scan number 24 end
N: Scan begin
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-92,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Found N: Device detect3ed: 58:9D:DF:C1:9E:39
devices, scan number 25 end
N: Scan begin
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-80,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Found 2 devices, scan number 26 end
N: Scan begin
N: Found 3 devices, scan number N27 end
N: Scan begin
N: Found 2 devices, scan number 28 end
N: Scan begin
N: Send on /BTtoMQTT/589DDFC19E39 msg {"id":"58:9D:DF:C1:9E:39","rssi":-99,"txpower":12}
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-88,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Found 1 devices, scan number 29 end
N: Scan begin
N: Found 2 devices, scan number 30 end
N: Scan begin
N: Send on /BTtoMQTT/CFC2BD2A8C0E msg {"id":"CF:C2:BD:2A:8C:0E","rssi":-99}
N: Found 3 devices, scan number 31 end
N: Scan begin
N: Send on /BTtoMQTT/FE502542C8A5 msg {"id":"FE:50:25:42:C8:A5","rssi":-95,"brand":"SwitchBot","model":"Meter (Plus)","model_id":"THX1/W230150X","tempc":19.5,"tempf":67.1,"hum":25,"batt":100}
N: Found 3 devices, scan number 32 end
N: Scan begin
N: Found 3 devices, scan number 33 end
N: Scan begin
N: Send on /BTtoMQTT/FE502542C8A5 msg {"id":"FE:50:25:42:C8:A5","rssi":-96}
N: Found 2 devices, scan number 34 end
N: Scan begin
N: Found 3 devices, scan number 35 end
N: Scan begin
N: Send on /BTtoMQTT/CFC2BD2A8C0E msg {"id":"CF:C2:BD:2A:8C:0E","rssi":-97}
N: Found 4 devices, scan number 36 end
N: Scan begin
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-87,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Found 3 devices, scan number 37N end
N: Scan begin
N: Found 2 devices, scan number N38 end
N: Scan begin
N: Send on /BTtoMQTT/FE502542C8A5 msg {"id":"FE:50:25:42:C8:A5","rssi":-95}
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-89,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Found 2 devices, scan number 39 end
N: Scan begin
N: Send on /SYStoMQTT msg {"uptime":184,"version":"v1.3.0","freemem":133008,"mqttport":"1883","mqttsecure":false,"tempc":44.44444,"freestack":3388,"rssi":-85,"SSID":"IoT-mqtt","BSSID":"86:2A:A8:C7:5F:A1","ip":"192.168.1.14","mac":"78:21:84:C6:B8:2C","lowpowermode":0,"interval":0,"intervalcnct":3600000,"scnct":39,"modules":["BT"]}
N: Send on /BTtoMQTT msg {"bleconnect":false,"interval":0,"activescan":true,"intervalcnct":3600000,"onlysensors":false,"hasspresence":false,"presenceTopic":"presence/","presenceUseBeaconUuid":false,"minrssi":-100,"extDecoderEnable":false,"extDecoderTopic":"undecoded","filterConnectable":false,"pubadvdata":false,"pubBeaconUuidForTopic":false,"ignoreWBlist":false,"btqblck":0,"btqsum":96,"btqsnd":87,"btqavg":1.103448}
N: Found 2 devices, scan number 40 end
N: Scan begin
N: Found 2 devices, scan number 41 end
N: Scan begin
N: Found 2 devices, scan number 42 end
N: Scan begin
N: Found 3 devices, scan number 43 end
N: Scan begin
N: Found 1 devices, scan number 44 end
N: Scan begin
N: Found 2 devices, scan number 45 end
N: Scan begin
NN: Device detect: ed: 58:9D:DF:C1:9E:39
Found 1 devices, scan number 46 end
N: Scan begin
N: Found 2 devices, scan number 47 end
N: Scan begin
N: Found 3 devices, scan number 48 end
N: Scan begin
N: Send on /BTtoMQTT/7C970D521947 msg {"id":"7C:97:0D:52:19:47","rssi":-78,"brand":"GENERIC","model":"MS-CDP","model_id":"MS-CDP","device":"Windows 10 Desktop","salt":"22186cd6","hash":"8dc4d048c1201b6e4e83104424a90bc3"}
N: Found 2 devices, scan number 49 end
N: Scan begin
N: Found 3 devices, scan number 50 end
N: Scan begin
