I have deployed esp32dev-multi_receiver on a bare ESP32 module and it is awesome to see it be able to decode data and all that.
Over serial I see it is able to pick up both 433 as well as the rtl_433 signals but only the RTL_433 gets written to MQTT. I accidentally got both to write to MQTT but it stopped working after I wiped the settings.
I tried the commands in RF gateways (433mhz/315mhz) | OpenMQTTGateway v1.4.0
commands/MQTTto433 “active”:true
N: Send on /SYStoMQTT msg {“uptime”:90,“version”:“v0.9.16”,“freemem”:98776,“mqttport”:“1883”,“mqttsecure”:false,“freestack”:4632,“rssi”:-38,“SSID”:“WiFi”,“BSSID”:“C8:B5:AD:D3:08:44”,“ip”:“192.168.0.132”,“mac”:“7C:9E:BD:4B:58:84”,“actRec”:3,“mhz”:433.92,“RTLminRssi”:-82,“RTLRssi”:0,“RTLCnt”:0,“modules”:[“RF”,“RF2”,“Pilight”,“RTL_433”]}
N: [ MQTT->OMG ]: {“value”:220936,“protocol”:1,“length”:22,“delay”:322,“mhz”:433.92}
N: Send on /RTL_433toMQTT/Smoke-GS558/2677 msg {“model”:“Smoke-GS558”,“id”:2677,“unit”:16,“learn”:0,“code”:“014eb0”,“protocol”:“Wireless Smoke and Heat Detector GS 558”,“rssi”:-37,“duration”:455839}
N: [ MQTT->OMG ]: {“value”:220936,“protocol”:1,“length”:22,“delay”:324,“mhz”:433.92}
N: [ MQTT->OMG ]: {“value”:3452,“protocol”:1,“length”:16,“delay”:323,“mhz”:433.92}
N: [ MQTT->OMG ]: {“value”:881268,“protocol”:1,“length”:24,“delay”:321,“mhz”:433.92}
N: Send on /RTL_433toMQTT/Smoke-GS558/29301 msg {“model”:“Smoke-GS558”,“id”:29301,“unit”:16,“learn”:0,“code”:“2e4eb0”,“protocol”:“Wireless Smoke and Heat Detector GS 558”,“rssi”:40,“duration”:334030}
