I have a LED attached to Pin15 and I use it with ONOFF.
This worked fine before. I updated to the newest dev firmware and the LED now glows slightly, but I’m not able to turn it on and off any more.
And also it seems like when I use the ON/OFF command the module resets and opens a Hotspot.
So I can control the LED again. The thing is the LED glows slightly when I plug in the OMG.
Just testet it with the older 0.9.2beta again. The LED glows a little but goes off automatically after a few seconds.
With the newest dev version it glows until I turn it off. Mind that the brightness of “LED turned on” and “glows” is not the same.
