I’m trying to use TheengsGateway with OpenHAB on a Raspberry Pi following this tutorial:
As I want to use TheengsGateway and not OMG on an ESP32, I skipped that part. I don’t know what that " Configure OpenMQTTGateway from the web portal" should be for, I assumed it should be part of thar ESP32 part.
My BLE Device (ATC_E45B09, Mi Temperature and Humidity Sensor) is discovered but stays in status “unknown”. What does that mean? What might have gone wrong? The MQTT Broker is “online”.
Log:
18:24:55.322 [WARN ] [tt.generic.ChannelStateTransformation] - Executing the JINJA-transformation failed: An error occurred while transformation. UnknownTokenException: Unknown token found: value_json.tempc | is_defined
