What’s Changed
This release is dedicated to the Theengs Plug, our first device sold with OpenMQTTGateway!
New BLE devices support:
Devices | Model | Measurements |
BlueCharm | BC08 | acceleration x/y/z-axis/voltage/temperature |
Jaalee | JHT F525 | temperature/humidity/battery |
Features:
- [HA Discovery] Add a check on device id before concatenating it to the device name by @1technophile in #1398
- [ONOFF] Fix actuator manual control with button press and overheat protection by @1technophile in #1403
- [BLE] Simplify the publication of advertisement data by @1technophile in #1408
- Update platformio.ini - For rtl_433_ESP release 0.1.6 by @NorthernMan54 in #1413
- Enable OOK_PULSE_MANCHESTER_ZEROBIT modulation decoder
- Add Oregon-CM160 ( oregon_scientific.c ) device decoder
- Added board ESP32 DOIT DevKit V1 with SX1278 module Ai-Thinker Ra01 by @diepeterpan in #1411
- Add device_class to MQTT Discovery for rtl_433_ESP by @NorthernMan54 in #1419
- add JSON parsing and hardware serial support to RS232 gateway by @mreijnde in #1409
- Update to ZdisplaySSD1306 to reduce overall resource usage, and enable message queuing by @NorthernMan54 in #1417
- [BT] Regular BLE system parameter pub by @1technophile in #1422
- [BT] BT connect based on time by @1technophile in #1423
- [BT] Bump Theengs Decoder to v1.1.0 by @1technophile in #1425
- [ONOFF] Add overcurrent protection by @1technophile in #1426
- [ONOFF] Publish state at the start and a given frequency by @1technophile in #1427
- [ONOFF] Improve Led display by @1technophile in #1430
Documentation:
- [DOCS] Generate board documentation automatically from platformio.ini by @1technophile in #1405
- [DOCS] Update vuepress by @1technophile in #1407
- [DOCS] Add Theengs Plug links by @1technophile in #1416
CI:
- [CI] Enable sub workflow call by @1technophile in #1406
- [CI] Change environments ini name by @1technophile in #1414
- [CI] Update actions versions by @1technophile in #1420
- [CI] Point development to decoder development by @1technophile in #1421
- [CI] Run development portal building every night by @1technophile in #1415
New Contributors
- @diepeterpan made their first contribution in #1411
- @mreijnde made their first contribution in #1409
Full Changelog: v1.2.0…v1.3.0
