Problem with TheengsGateway addons
hello, I am a vm with hasso, I have a sena key which is connected to the vm, with roon assistant, it was seen and worked well, on the other hand with TheengsGateway addon nothing works, here is part of my configuration
if you want more info let me know
What do you see in the logs of the addon ?
Voilà ce que vois.
Could you change the configuration, and put the log level to DEBUG and share again the log extract?
gaterway
hello, well I found it was my bluetooth key which was not detected in ha, on the other hand he does not see that watches are not for me
INFO:BLEGateway:publishing device `{'name': 'Mi Smart Band 5', 'id': 'FD:B9:C6:35:59:3A', 'rssi': -77, 'brand': 'Xiaomi/Amazfit', 'model': 'Mi Band/Smart Watch', 'model_id': 'MB/SW', 'steps': 51, 'device': 'Xiaomi/Amazfit Tracker', 'mfr': 'Anhui Huami Information Technology Co., Ltd.'}` ERROR:root:A message handler raised an exception: Extra data: line 1 column 165 (char 164). Traceback (most recent call last): File "src/dbus_fast/message_bus.py", line 811, in dbus_fast.message_bus.BaseMessageBus._process_message File "/usr/local/lib/python3.9/dist-packages/bleak/backends/bluezdbus/manager.py", line 848, in _parse_msg self._run_advertisement_callbacks( File "/usr/local/lib/python3.9/dist-packages/bleak/backends/bluezdbus/manager.py", line 892, in _run_advertisement_callbacks callback(device_path, device.copy()) File "/usr/local/lib/python3.9/dist-packages/bleak/backends/bluezdbus/scanner.py", line 279, in _handle_advertising_data self._callback(device, advertisement_data) File "/usr/local/lib/python3.9/dist-packages/TheengsGateway/ble_gateway.py", line 339, in detection_callback gw.publish_device_info( File "/usr/local/lib/python3.9/dist-packages/TheengsGateway/discovery.py", line 110, in publish_device_info pub_device["properties"] = json.loads( File "/usr/lib/python3.9/json/__init__.py", line 346, in loads return _default_decoder.decode(s) File "/usr/lib/python3.9/json/decoder.py", line 340, in decode raise JSONDecodeError("Extra data", s, end) json.decoder.JSONDecodeError: Extra data: line 1 column 165 (char 164) DEBUG:BLEGateway:73:3D:BA:2E:7B:28:AdvertisementData(manufacturer_data={224: b'\x01\xdb\xcae=+'}, service_data={'0000fe9f-0000-1000-8000-00805f9b34fb': b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'}, service_uuids=['0000fe9f-0000-1000-8000-00805f9b34fb'], rssi=-72)
  File "/usr/local/lib/python3.9/dist-packages/bleak/backends/bluezdbus/manager.py", line 778, in _parse_msg
json.decoder.JSONDecodeError: Extra data: line 1 column 165 (char 164)```
Thanks for reporting this, it’s a bug in Theengs Decoder and will be fixed in the next release.
hi i have this error too
Also for the Mi Smart Band 5?
hi, i have mi band 3, mi band 5, AMAZFIT GTR and 4 nut finder3
Well, this looks like the same error as your previous one, so you’ll just have to wait for the next Theengs Decoder release. When it’s published, you’ll just need to update it with pip install -U TheengsDecoder and then restart Theengs Gateway.
even when you have the addons, you have to do the ssh command?
Hi @titof2375
While I’m not sure why there are build errors for you when trying to pip update Theengs Decoder, uninstalling and then installing the Theengs Gateway Add-on afresh should give you all the latest dependencies, i.e. Theengs Decoder, as well.
Might be easier than trying to separately update Decoder.
thanks to you thanks to you
